12-Oct-2016, 02:05 PM (This post was last modified: 12-Oct-2016, 02:06 PM by HamsterFPV.)
Looks like Flysky are releasing a new FS-i6 along with a new receiver. It is currently on Banggood for pre order.
FS-i6X Specifications:
Item: FS-i6X RC Transmitter
Channel: 6-10 (Default 6)
Model Type: Fixed-Wing/Glider/Helicopter
RF Range: 2.408-2.475GHz
RF Power: < 20dBm
RF Channel: 135
Bandwidth: 500KHz
2.4GHz System: AFHDS 2A / AFDHS
Modulation Type: GFSK
Stick Resolution 4096
Low Voltage Warning: < 4.2V
DSC port: PS/2 Port PPM
Chargeable: No
Antenna Length: 26mm (Dual Antenna)
Weight: 392g
Power: 6V DC 1.5AA*4
Display: STNTransflective Display, LCD 128x64 Lattice, VA 73x39mm, LCD with white backlight
On-line Update: Yes
Color: Black
Certificate: CE0678, FCC ID: N4ZFLYSKYI6X
http://www.banggood.com/Flysky-FS-i6X-2_...utmid=1078
RF Power: < 20dBm
RF Channel: 135
Bandwidth: 500KHz
Chargeable: No
Weight: 392g
On-line Update: Yes
Color: Black
Current quad: ZMR 250 / DYS SE2205 / Littlebee 20A ESCs / Drone Lab 1500 4S / Naze32 Rev5 / BF 2.7.1
