Flysky FS-A8s (micro receiver) ibus/sbus/ppm
so far only headsup for all "non taranis guys"
http://www.banggood.com/Flysky-FS-A8S-2_...92861.html
Brand Name:Flysky
Item Name:FS-A8S Receiver
Channels: PPM 8CH, i-BUS 18CH
Frequency range: 2.408-2.475GHz
Band width: 500KHz
Band number: 135
RX Sensitivity: -92 dBm
Code type: GFSK
Transfer method: FHSS
Data output: 1.5mm*3 Pin PPM/i-BUS/S.BUS
Antenna length: 26mm
Input power supply: 4.0-8.4V
Display method: LED
Empty without interference ground distance ( 1 m from the ground to receive): >300m
Working current: 40mA
Each channel data: depend on the transmitter
Channel delay: <15mS
Weight: TBD
Certificate: CE0678, FCCID: N45ZA8S00
Compatible Transmitter: Compatible with FS-i4,FS-i6,FS-i10,FS-GT2E,FS-GT2G,FS-GT2F
small, ibus/sbus/ppm, antena that looks like can be replaced...
waiting for it... as soon as ill get it and do few tests (range) ill post a review of it... only one problem ... it is not avaliable yet Smile
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
[-] The following 2 users Like Grisha0's post:
  • Oscar, KonradS
Ordered bunch of those... will do review as soon as they will arrive Smile
finally 3" will not have "space" problems Smile
All the best
Maan I had less problems with a huge ia6b on my 3" than I had on my recently built NOX5R.... that is a cramped build...
Waiting for a review Wink or my own units ;p
It wasn't easy to fit a frsky xsr on the qav-x frame either, im sure a lot of people will appreciate the size Smile
Btw, the weight is 1.2g, pretty nice as well
  Tip & Trick FlySky i6X + OpenTX + ELRS + INAV screen psicho100pro 9 7,742 14-Apr-2024, 09:05 AM
Last Post: psicho100pro
  Crossfire Micro TX not binding to Nano RX TonyTheDronie 9 30,380 21-Mar-2024, 07:38 PM
Last Post: BigBeard
  Help FrSky r xsr receiver not entering bind mode August 1 99 05-Mar-2024, 08:49 PM
Last Post: August
  [Solved] Don't get any input from ELRS receiver in BetaFlight aprudnikoff 4 278 03-Mar-2024, 01:03 AM
Last Post: aprudnikoff
  Help Tango 2 does not connect to the (TBS CRSF nano RX)drone receiver but updates it Maksym 1 161 25-Feb-2024, 12:34 AM
Last Post: Cake
