Flycolor Raptor BLHeli_S 2 - 4S 30A OPTO Brushless ESC
Thumbs Up
This is a Flycolor Raptor BLHeli_S  2 - 4S 30A OPTO Brushless ESC and was provided to me by GEARBEST for review.  They came four to a package and included a very complete set of user instructions and info
 [Image: wahspzkl.jpg]
 Commonly Advertised Features:
Fast: MCU with an operating frequency of 50MHz.
Small and light:  6.3g at 29 x 12.5 x 5mm.
BLHeli-S firmware:  Reduces response time and deadband of throttle, makes motor rotation more sustainable, and effectively reduces the noise of motors.
Adjustable speed: It supports the common 1 - 2ms pulse-width input, Oneshot125 ( 125 - 250us ), Oneshot42 ( 41.7 - 83.3us ) and Multishot ( 5 - 25us -  Outstanding compatibility with high KV motors. Maximum speed – up to 500k eRPM. DShot150, DShot300, DShot600 are also available.
Damped Light Mode: In this mode, power is withdrawn automatically during deceleration to improve the flight efficiency. As a result, the motor responds more rapidly and stability is improved
Anti-electromagnetic interference: Twisted-pair cable can effectively diminish the electromagnetic interference when signals pass through wires.
First Impressions:
They’re small….really small (29 x 12.5 x 5mm) and only 6.3 grams. I have them mounted on my latest build (Tweaker5) and they fit easily.  They would also fit my 160 with no problems at all.
[Image: fzpX3zwl.jpg]
Quality of construction seems first rate using an intelligent layout.  Solder tabs are extended and exposed for easy access.
The documentation was concise and clear….which is a rarity in itself!
[Image: MEfOrb4l.jpg]
[Image: OQyxAROl.jpg]
According to the user instructions that were provided with units I received, these ESC’s provide support for Oneshot 125&42 and MultiShot.  No mention is made about Dshot.  However, on the GEARBEST website it states that support for Dshot150, 300 & 600 is provided by these ESC’s. The ESC’s provided were preloaded with BLheli_”A_H_40” revision “16.3”.  When I went to update them with the latest version the following warning showed up:
[Image: Ilf40acl.jpg]
Using pass through, I flashed them anyway and there were no issues.
These allow for bidirectional motor rotation (for all the 3D guys out there).
Motor response is very smooth and quick.
Conclusions:
These are by far the best ESC’s I have used to date.  They are small, light, well made and easy to solder to.  The fact they allow bidirectional rotation allows me to venture into 3D flying if I want to at some point (yeah……like THAT’S ever going to happen).
I cannot speak to longevity or reliability because I have not had them long enough.  However, I have not heard of any significant problems with them.
That’s about it.  Knowing what I know at this point, I would not hesitate to purchase these for my next build.
[-] The following 2 users Like sirdude's post:
  • sloscotty, KonradS
  Help TMotor F55 Pro ii ESC won't power FC after crash EyeBotXander 2 260 11-Apr-2024, 09:32 PM
Last Post: EyeBotXander
  Solved ESC and FC rebooting during motortest zsolth 5 116 11-Apr-2024, 01:34 PM
Last Post: zsolth
  Solved Cannot connect ESC derange 2 143 22-Mar-2024, 10:05 PM
Last Post: derange
  Solved Cannot recognise 1 Esc at 4in 1 Esc Mad35 11 216 12-Mar-2024, 01:47 PM
  Help ESC working but motor not spinning Prashant1901 1 145 10-Mar-2024, 02:09 AM
