Fly away drone
Emax skyline 32 acro
littlebee 30amp ESC
EMAX RS2205 2300kv
FRSKY X4RSB
TBS TANGO RADIO
setup FC in BETAFLIGHT and calibrated ESC. all motors work properly we operated through betaflight.
when i power the quad without props and input a very small amount of throttle without increasing it any, the motors will gradually increase in RPM until i move the stick back to zero throttle. its does this constantly we checked the receiver inputs on betaflight and the receiver input is remaining at one valve. please help. i read another post on this same issue possibly and he raised the low pass filter to solve the problem. i made changes to the low pass filters settings and it did not seem to help.
Hm this sounds pretty normal without props... the motors try to correct even the smallest errors generated by vibration or electrical noise, but because they are not effective without props they try to push harder and harder. Once your throttle stick goes back below min_check, these accumulated errors (i-term) are cancelled out.
You can expect it to work pretty normal with props on and after getting some air between quad and ground. Smile
(12-Mar-2017, 11:40 PM)fftunes Wrote: Hm this sounds pretty normal without props... the motors try to correct even the smallest errors generated by vibration or electrical noise, but because they are not effective without props they try to push harder and harder. Once your throttle stick goes back below min_check, these accumulated errors (i-term) are cancelled out.
Thanks,
im an idiot... i found that the radio had to set trim on radio...  Thumbs Up i got in in the air, now its just if i can keep it there...
[-] The following 1 user Likes Alex's post:
  • fftunes
Your flight controller has an F1 processor and is not exactly the most powerful. It's possible that you might have a CPU load that is way too high.
When you are connected to the Betaflight configurator, what does the status line tell you your CPU loading is?
Also, you shouldn't be using the trims on your radio. You should set all the trims to centred and leave them alone. Then you should make sure that the channel values go from 1000 to 2000 and are centred at 1500 for pitch, roll and yaw. If the range is not large enough, you should use the travel adjust on your radio to fix that. If the channel is not centred at 1500, you should use the subtrim on your radio to fix it.
  Build Helios - 3.5” Sub-250g (Sub 160g possible) DJI O3 Drone – Frame/Build Thread Recursion 12 1,823 25-Mar-2024, 10:28 PM
Last Post: Recursion
  Build Aerospace Engineer + 5" Drone = EnzoDrone BigBeard 3 182 22-Mar-2024, 04:33 AM
Last Post: Bud13420
  Can anyone recommend a mini drone? gabrilesi95 9 894 05-Dec-2023, 12:32 AM
Last Post: voodoo614
  Help my drone crashed today ... adirb 18 2,007 29-Jun-2023, 01:40 AM
Last Post: FPVme
  4" racing drone doing death rolls and won't disarm EyeBotXander 45 2,200 29-May-2023, 12:42 AM
Last Post: ClarkFPV3
