Flashing custom BF hex file
I found myself needing to restore the BF hex file from the manufacturer's website, but for some reason was unable to get if flashed to my AIO. I was able to flash BF firmware when loaded online from within the BF configurator, but when it came to the custom file, the configurator would load the local hex file, but then freeze up when clicking on the flash firmware button?!?
Must have spent over an hour, trying different flash options, DFU mode, went through several cables, different PCs trying to figure out what was wrong. I did not see any error messages in BF configurator at all.
It turns out its something as simple as selecting DEVELOPMENT in the flasher option, but it would have been nice if configurator gave a simple message instead of just freezing up.
[Image: M7uhJBcl.png]
  • Lemonyleprosy
  After flashing the ESC using JESC zomer 1 179 18-Sep-2023, 09:50 AM
Last Post: voodoo614
  Betafpv spi elrs 12a aio bricked after flashing firmware Dronewhooper 14 1,231 04-Feb-2023, 01:03 AM
  Can flashing the wrong fc firmware damage components Rob Axel 1 964 25-Sep-2022, 10:16 AM
  Help solid blue light, flashing red light nickruffier 8 2,630 27-Mar-2022, 06:13 AM
Last Post: nickruffier
  Rushfpv Blade - flashing - SOLVED mihhail 1 476 24-Dec-2021, 09:24 PM
Last Post: mihhail
