Flash DYS SN16A ESC through FC and Cleanflight
Does anyone know if its possible to flash BLHeli firmware to DYS SN16A ESCs through Cleanflight (flight controller)?
I'm using a Naze Rev6 for this, do you know if it supports passthrough?
edit: so if i don't have BLheli on it previously, do I need a USB linker to flash BLHeli on them?
Naze32 Rev6 should work, since my Naze rev5 definitely does.
But You CANNOT flash simonK bootloader ESCs via pass-through, and Dys SN16A has simonK bootloader that comes from the factory (I think), even though they may have BLHeli Firmware.
To use Clean Flight to flash you have to have BLHeli bootloader on the ESC.
thanks! so to flash the BLHeli bootloader on those ESC's, can I use a FTDI adapter? would Arduino work?
An FTDI adapter only gives you serial port. To flash ESC-s you need a micro-controller with loaded firmware that communicates with the ESC.
It can be an USB linker or an Arduino programmed as a linker.
The Arduino works perfectly.
  Help ESC desync issues oyvinla 24 16,694 20-Feb-2023, 01:26 AM
Last Post: kibbycabbit
  DJI FPV Drone Combo / Dji Flash LaserBrain 1 445 22-Feb-2021, 01:45 PM
Last Post: Ljholland
  Help Brushless motor or ESC broken? Not working properly after full throttle Niujaus 5 8,217 30-Apr-2019, 12:27 PM
Last Post: Drone0fPrey
  ESC mounting outside the box Krohsis 8 1,454 16-Mar-2019, 09:55 PM
Last Post: Krohsis
  Are Tattu ESC’s and Motors any good sushicanfly 2 699 17-Sep-2018, 03:19 AM
Last Post: rcxlfjne
