first time flying race drone..issue?
So i have a wizard x220 that i got ebay from a seller used and got it and he placed long screws into motors and ruined the stator/windings and i just bit the bullet and got emax 2205/2300 and got new esc's which im not so sure about littlebee 20amp esc. my wizard has sp racing flightboard setup with pdb but problem is i checked my horizon flight on betaflight blackbox and at one time motor #1 got to 100% and others was around 50ish. ive got a slight oscillation problem and seems to not have the power it should.. in video i did have 3s lipo but on 4s it does pickup but seems like not enough. so im new to this and pids really do confuse me how it works. i also on think my p-roll on blackbox is high what would that mean or do i have something bad going on? also littlebee 20esc do they need a special process before flying with them? i calibrated esc with betaflight 3.0.1 and hear that littlebee esc are in need of capacitors? i had blheli esc that had only the signal wire hooked and not ground so littlebees i dont have the small ground hooked up neither to the board. Sorry for all these questions and hope to get good enough to help others
Caps are for protecting the rest of the electronics from back-fed voltage spikes as well as levelling voltage in general. Ground signal wire helps reducing voltage fluctuations on signal wire.
The issue with that one motor looks like either bad motor/esc or maybe bad solder joint in between.
(24-Feb-2017, 10:14 AM)fftunes Wrote: Caps are for protecting the rest of the electronics from back-fed voltage spikes as well as levelling voltage in general. Ground signal wire helps reducing voltage fluctuations on signal wire.
weird question i guess of course you know who mr steel is, well how does his quad sound so high pitch and fast but yet mine sounds like its weak even 4s lipo? emax 2205/2300kv with littlebee esc 20amp. What would be a good capacitor to put? so i need to put cap pack on powerside of esc to board? Ive only been flying horizon mode so does it reduce my power?
Yh caps are meant to put directly on escs, or pdb. It's important they are low-ESR. Most people use 35V, 220uf if mounted to escs, 470-1000uf if mounted to pdb...
But i think the bigger issue is that one esc/motor that's bad. If in normal flight log shows 100% motor command on one, 50% on others, you'll miss out on half the available power because the good motors can't push harder than the weakest one in order to keep attitude...
Maybe try to redo the soldering on that one motor/esc to be sure.
(25-Feb-2017, 02:42 AM)ftj_85 Wrote: weird question i guess of course you know who mr steel is, well how does his quad sound so high pitch and fast but yet mine sounds like its weak even 4s lipo? emax 2205/2300kv with littlebee esc 20amp. What would be a good capacitor to put? so i need to put cap pack on powerside of esc to board? Ive only been flying horizon mode so does it reduce my power?
His motors are slightly higher kv (2350kv) and the props will also do something with the sound. In general, the more blades, the higher pitch sound.
I saw your vape cloud (fellow vaper) and was like damn he does have a problem! ROFL I thought something caught fire Tongue untill it dawned on me what it was lol Wink
The Obsession IS Real!
thanks guys, yeh droneofprey im going to atlanta ga for vape convention 25/26th march. soi found a big issue with drone the bearing even though motors was new the top bearing is bad in two motors on y axis... so amazon is giving me crap so far and not sure what there going to do. I should knew that something was terrible wrong cause for emax 2205/2300kv not having no punch at all or power. so so now i did something that is costing me a good bit i ordered a alien rotor riot frame and will have droneproz 2206/2300kv with littlebee esc 30amp bl-helis(bb2 chips) and it will have the bluejay f4 with osd,im adding my rotor riot runcam 110deg fov and immersion tramp vtx for fatshark attitude v2. Hoping this will have way better power and fly good. I got question for anyone could help me with littlebee 30amp esc the air break is bad for throwing lots of voltage spikes what should i do here to keep anything from frying i wanna make this alien last a long time and get to point im tired of flying not tired of it blowing up
(05-Mar-2017, 03:54 AM)ftj_85 Wrote: thanks guys, yeh droneofprey im going to atlanta ga for vape convention 25/26th march. soi found a big issue with drone the bearing even though motors was new the top bearing is bad in two motors on y axis... so amazon is giving me crap so far and not sure what there going to do. I should knew that something was terrible wrong cause for emax 2205/2300kv not having no punch at all or power. so so now i did something that is costing me a good bit i ordered a alien rotor riot frame and will have droneproz 2206/2300kv with littlebee esc 30amp bl-helis(bb2 chips) and it will have the bluejay f4 with osd,im adding my rotor riot runcam 110deg fov and immersion tramp vtx for fatshark attitude v2. Hoping this will have way better power and fly good. I got question for anyone could help me with littlebee 30amp esc the air break is bad for throwing lots of voltage spikes what should i do here to keep anything from frying i wanna make this alien last a long time and get to point im tired of flying not tired of it blowing up
What looptimes are you running? Oneshot125? I had the same issue as you describe in the video when running 4k and 20a littlebees with oneshot125. Oneshot 125 can't keep up with 4k
i have a flysky fs i6 transmitter with fsia6 receiver i think i'm using the correct channel map but this is the result.
Looks like constant failsafe, no?
  Flying along the Creek and Around the Forest Track FPVme 3 208 15-Mar-2024, 02:50 AM
Last Post: drumgod
  World's Fastest FPV Camera Drone vs F1 Car SnowLeopardFPV 9 398 12-Mar-2024, 03:22 PM
Last Post: IanS
  Flying in the Snowy Forest FPVme 11 425 26-Jan-2024, 01:12 PM
Last Post: FPVme
  Been a long time since I flew!!! ebeez 0 212 02-Jan-2024, 01:42 AM
Last Post: ebeez
  Pilot error, dog bites drone out of air. FPVme 2 288 26-Aug-2023, 04:15 PM
Last Post: FPVme
