26-Mar-2017, 11:54 PM
Heya Forum!
..writing to you after a sleepless night (..*hmm, if I was this frenetic about a girl, they'd probably have me locked away by now.. ), my first haphazardous built and my first FPV lawn-mowing experiences..
*Golly, is-that-thing-fassssttt!!! After the initial refrain, this thing quickly grabs your heart and snuggles up against it. *what a blast!!
I'm far from being halfway proficient, but after stuffing it with freshly cut grass upon landing (..fellow beginners: Soft underground is really, really, really a good idea, but a mown meadow should be favored. On the other hand, my Shuriken smells of freshly cut grass now, and somehow that's really nice! :-)
A little word of advice: Take along your old toothbrush when you do your first attempts! At the beginning you'll just "lag" on disarming your quad after landing, and even within just one second, the propellers will hungrily stuff the innards of your quad with all sorts of biological products. I would have loved to have one today in the field, but was stuck with pinching my "veggie-quad" instead..
So QUESTION to the Forum: How do you guys clean your quad? I'm assuming that this happens to everyone, once in a while..: Dried grass is really difficult to remove without taking the whole thing apart..
But all this wasn't the subject of this thread, so:
I did 3 Lipos on my first FPV-attempt today. It was dawning, and the low sun wasn't really improving the already very grainy picture..:
Has anybody had the opportunity to compare the Eachine VR D2-headmount (..do you call a screen "goggles" as well? I mean, it's just one screen, and not of what pops in mind when hearing the word "goggles". Rather "forehead-wrench", or "accomodation-chamber-of-torture"..
The picture feels pretty darn close to the eyes, at the beginning I was unvoluntarily moving my head backwards the whole time. Additionally, somehow a lot of readings popped up on the screen and I could not make them go away. Had to do my maiden while looking at things through a page of newspaper - at least that's how it felt
This sure takes a lot getting used to, I'm aware of that. Just hoping that someone's going to say: *Ah, that screen-headmount is not really good, the quality on my Fatsharks (..Dominator V3, for instance..? ) is much better and makes it easier to orientate. Reallyreally hoping - otherwise it's really, really, reeeeaaallly difficult (..what it is anyway, as we all know..), and it will take a lot of what I don't really have: Patience..
As far as my first built is concerned, know that:
a. It was neither planned, nor shopped for - just had an iFlight iX2-frame lying around (bought out of curiosity & cheap)
b. The components used are not intended for micro-quads, even though they're so tiny. (..for instance the HGLRC xjb v1-module, which made me drop off my chair as I found the maximal amperage of the 4-in-1 ESC's: Apparently 25 Amps each, and could sport up to 6s (..rreeeaaalllyyy???) Lipos. If that's really true, it's a really good combo: Quick installation and setup!
Of course, the iX2 got a bit heavy - despite my initial discipline to keep it well organised and doing a clean built in general: The mess will invariably strike back, but you'll have to use less swearwords when cleaning up your workplace...
However, the FC and 4in1 ESC does not really fit into this frame as it was developed for a different "x-style". In order to use it, I had to rotate the yaw-plane in betaflight, which was quite tedious.
The whole building procedure was a great experience, though. A lot of little problems will pop up along the way (..like "how do I fix this on a sunday, when it's really difficult to organize some decent aids/tape/glue - you name it..), especially if you start "just like that" - that's what I did, and I really don't recommend it. In my case it was because I just couldn't get over the defeat with the Kingkong 90GT, where everything seemed so simple (..on youtube, that is ;-))
PLAN YOUR BUILT!!
Take your time in chosing the components, if I would have known this forum before ordering as excitedly as a squirrel on cocaine over the internet, I would have avoided a lot of tinkering and ultimately resigning..
Take your time as well to see how things fit together, and try to keep wire routing (..get enough wire in the right gauges, too!! Don't forget that, or you'll be stuck like me on a sunday taking apart battery charging boards for plugs and cables, ending up with too thin wires on one side, and way too thick ones getting in your way when screwing the whole thing together.. )
Loctite might be a good idea, too! You don't need to go for the catastrophe-proof strength (..red color? green? I used the blue one which is medium and seems plenty).
Don't put it directly onto the screws, you'll end up with a Loctite-screw-salad and its sauce oozing all over. Take a little piece of aluminum foil (stays put and liquid does not flow away like with plastic foil), put a droplet (..that's enough, really) on it and dip a little bit of the thread into it. It's easier if you put the bold/screw already on the screwdriver: You can give the screw a little turn, and it keeps your fingertips clean. The stuff polymerizes (hardens) under exclusion of air/oxygen, that is cool because it solidifies only when you use the screw - no need to rush..
As I just said - keep it orderly, because towards completion, things unvariably will get tight/messy. It looks a lot better, too, and makes checking on the correct wire connections easier than when fishing through a bowl of electric wire spaghettis..
Concerning the "solutions on the way", cable ties/binders come in handy. Get one of those boxes with lots of different sizes. Stabilizing antenna coax cables, mounting and securing stuff.. If you don't have infinite time at hand and you don't own a 3-d printer (I don't - yet.. ), you'll grow to love these little versatile plastic thingies.
Another thing is sticky foam tape. I wish I had bought not only double-sided one, but you can leave the protective foil on on one side as an intermediate remedy. Take into consideration that the protective plastic foil will shear off over time (..especially with higher temperatures..) and accumulate/stick to all sorts of things.
I came up with this solution for my "landing pads"..:
(..*wait, Imgur does not want my picture..)
PLAN YOUR BUILT!!
