First brushless built motors problem
Hello, i've a problem with my first brushless "serious" built .
I'm posting here because i think it's the appropriate section.(sorry for my bad English)
I've a twitching/stuttering motor problem.
On the bench the motors are running ok but when armed and just hovering there are something like very fast bursts of "cuts of power" in a fraction of second(making a sketchy braking/stuttering sound).It seems happening when pushing up throttle even gently.
Soldering and connections are ok since on bench i've no problem in all throttle ranges and touching the wires when motors running didn't change the sound or rpms feeling.
The motors get warm in a minute with props on too.
Props used: dalprop 5040 tri (very flexy) and gemfan 5040 hybrid 2blades(stiffer)
My setup:
Gep vx 5 frame,racerstar rf 2205-2300kv,racerstar ms35a(flashed 16.6 ah-20 firmware), xracer f303v3.1(latest fw),4s lipo.
here's my dump:
# Betaflight / X_RACERSPI 3.1.5 Feb  7 2017 / 22:34:57 (4646f9d)
name Gep Ge VX 5
resource BEEPER 1 C15
resource MOTOR 1 A06
resource MOTOR 2 A07
resource MOTOR 3 A11
resource MOTOR 4 A12
resource MOTOR 5 B08
resource MOTOR 6 B09
resource MOTOR 7 A02
resource MOTOR 8 A03
resource MOTOR 9 A08
resource MOTOR 10 NONE
resource MOTOR 11 NONE
resource MOTOR 12 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 A00
resource PWM 1 A00
resource PWM 2 A01
resource PWM 3 B11
resource PWM 4 B10
resource PWM 5 B00
resource PWM 6 B01
resource PWM 7 NONE
resource PWM 8 NONE
resource LED_STRIP 1 A08
mixer QUADX
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -OSD
feature -BLACKBOX
feature -TRANSPONDER
feature -AIRMODE
feature -SDCARD
feature -VTX
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature VBAT
feature RX_SERIAL
feature MOTOR_STOP
feature FAILSAFE
feature LED_STRIP
feature BLACKBOX
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
map TAER1234
led 0 15,15::CTI:2
led 1 15,14::CTI:2
led 2 15,13::CTI:2
led 3 15,1::CTI:2
led 4 15,0::CTI:2
led 5 0,15::CTI:2
led 6 0,14::CTI:2
led 7 0,13::CTI:2
led 8 0,1::CTI:2
led 9 0,0::CTI:2
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 0 1550 2100
aux 1 2 1 1700 2100
aux 2 0 0 900 900
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
rxrange 0 1067 1928
rxrange 1 1067 1928
rxrange 2 1067 1928
rxrange 3 1068 1923
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
set task_statistics = ON
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rc_interp = AUTO
set rc_interp_ch = RP
set rc_interp_int = 19
set rssi_ppm_invert = OFF
set fpv_mix_degrees = 0
set max_aux_channels = 6
set debug_mode = NONE
set min_throttle = 1050
set max_throttle = 2000
set digital_idle_percent =  4.500
set use_unsynced_pwm = ON
set motor_pwm_protocol = MULTISHOT
set motor_pwm_rate = 32000
set disarm_kill_switch = ON
set small_angle = 25
set fixedwing_althold_dir = 1
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set beeper_inversion = ON
set beeper_od = OFF
set serialrx_provider = SPEK2048
set sbus_inversion = ON
set spektrum_sat_bind = 0
set spektrum_sat_bind_autorst = 1
set tlm_switch = OFF
set tlm_inversion = ON
set sport_halfduplex = ON
set frsky_default_lat =  0.000
set frsky_default_long =  0.000
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set bat_capacity = 0
set vbat_scale = 110
set vbat_hysteresis = 1
set ibat_scale = 400
set ibat_offset = 0
set mwii_ibat_output = OFF
set current_meter_type = ADC
set battery_meter_type = ADC
set bat_detect_thresh = 55
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_yaw = 0
set gyro_lpf = OFF
set gyro_sync_denom = 1
set gyro_isr_update = OFF
set gyro_use_32khz = OFF
set gyro_lowpass_type = PT1
set gyro_lowpass = 90
set gyro_notch1_hz = 400
set gyro_notch1_cut = 300
set gyro_notch2_hz = 200
set gyro_notch2_cut = 100
set moron_threshold = 48
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set thr_corr_value = 0
set thr_corr_angle = 800
set yaw_control_direction = 1
set yaw_motor_direction = 1
set servo_center_pulse = 1500
set tri_unarmed_servo = ON
set servo_lowpass_hz = 400
set servo_lowpass = OFF
set servo_pwm_rate = 50
set gimbal_mode = NORMAL
set airmode_start_throttle = 1350
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_kill_switch = ON
set failsafe_procedure = DROP
set acc_hardware = AUTO
set acc_lpf_hz = 10
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set acc_trim_roll = 0
set pid_process_denom = 2
set blackbox_rate_num = 1
set blackbox_rate_denom = 4
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set yaw_p_limit = 500
set pidsum_limit =  0.500
set d_lowpass_type = BIQUAD
set d_lowpass = 100
set d_notch_hz = 260
set d_notch_cut = 160
set vbat_pid_gain = OFF
set pid_at_min_throttle = ON
set anti_gravity_thresh = 350
set anti_gravity_gain =  1.000
set setpoint_relax_ratio = 25
set d_setpoint_weight = 190
set yaw_accel_limit =  10.000
set accel_limit =  0.000
set iterm_windup = 50
set yaw_lowpass = 0
set p_pitch = 58
set i_pitch = 50
set d_pitch = 19
set p_roll = 44
set i_roll = 40
set d_roll = 17
set p_yaw = 70
set i_yaw = 45
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
set level_sensitivity = 55
set level_limit = 55
set rc_rate = 100
set rc_rate_yaw = 100
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set pitch_srate = 70
set yaw_srate = 70
set tpa_rate = 10
set tpa_breakpoint = 1650
And Blackbox log
https://www.dropbox.com/s/4a9ycmmeuir1n4...7.BFL?dl=0
blheli screenshot:
[url=https://www.dropbox.com/s/4a9ycmmeuir1n48/BLACKBOX_LOG_Gep_Ge%20VX%205_20170222_135657.BFL?dl=0][/url]
[Image: UfNv02Hl.png]
Please someone help me Cry Cry before i dismantle everything and rebuilt all from zero.
Tia
Lorenzo
What size is the quad, and do you have the fc softmounted (i think you said you added o-rings, but it might be not that trivial - if screws are still directly touching the fc, yaw noise/vibrations will still be transferred from frame to fc).
To test first wether it's a yaw problem, you could lower or even zero yaw P.
If it goes away then, you would have to improve the softmounting (larger holes in fc, or smaller screws, and possibly bevel the fc holes so the o-rings automatically center the screws.
Does the fc have onboard flash or sd-card slot? A log could help in case it's something else... Also, did you try to lower P on pitch or roll, just to test?
Hi fftunes,yes i have a 16mb flash onboard and blackbox log and cli dump are attached.
Frame is: http://geprc.com/products/multirotors/gep-vx5/
It looks from the CLI dump that you are running 32k unsynced multishot, am I right? If so, have you tried reducing it to 16k, 8k or same as the pid loop? I don't know if those escs can handle 32k?
Yes i'm running 32khz, the escs are almost a fresh release http://www.racerstar.com/Racerstar-MS35A-ESC-p-43.html they can run dshot...
seems they are EFM8BB21 ztw polaris rebranded escs.
I would try to reduce the update frequency or switch to dshot600. It could be that you'll need to remove a capacitor on the escs. if so, try dshot300 instead. Like I said, I don't know how your escs are, but I know that some runs fine on 32k, some don't
If your ESCs are DShot capable, why don't you try it. And as said above, try dropping to 8k/8k. I'm using a Brain RE1 with DYS SXD 30 amp ESCs with DShot 600 and I've tried every combo from 32k/32k down to 8k/4k. It didn't like 32k/32k but everything else ran great. In fact I couldn't even tell the difference. But that may just because I still suck as a pilot hahaha
Sorry didn't see log link before, will check a bit later on pc.
I wouldn't recommend dshot now though as not to complicate things, as your quad basically roughly works for now, but yeah as others mentioned maybe lower esc freq. to 8k just to make sure escs are not the issue.
But another question, do you have a capacitor on pdb or escs?
Hm on the other hand, if no caps, and electrical noise is the issue, then dshot might help the escs at least...
Thanks to all.
Now lowering 5 points of D on roll&pitch seem getting better but i still have some twitchings randomly.(same serie of two"crak-crick" sounds)
Tonight i'll try reducing khzs and redo the Fc insulation with softer oring from 1/8 rc buggy shocks,maybe it will works..
Dshot is still far from my soldering/reworking skills,so i'll try to figure it out with oldschool Multishot protocol for now.
1st thing i notice in the log: your rc command looks bad. Means you have either misconfigured your tx (sending too long pulses) or misconfigured rc-smoothing in fc. What tx/rx are you using? Or did you disable rc-smoothing completely? Either way your tx is sending in 21ms intervals, which actually look unsmoothed (big steps) which in turn causes big D-term spikes.
A quick dirty fix would be to set rc-smoothing to manual and interval to 21ms. But that's suboptimal.
2nd thing is, yaw gyro looks noisy. You could try to lower yaw P if it doesn't hurt control, but it probably does; you could enable yaw lowcut filter and set it to 60-70hz, but it probably doesn't help much; means you have to improve the soft-mounting i think...
Unless it is electrical noise that's messing with the gyro - not sure you mentioned wether you have caps installed on pdb or escs?
I am using a spektrum dx6i with diversity dsmx sat. With defualt settings the values are approx 1140-1840ish so i increased end points closer to correct value and then rcrange cli command to get 1000-2000.
Never modified rc smoothing since in receiver tab i have no visible jitter.
With dsmx sat, shouldn't you be able to set it to 11ms in the dx6i? Under the bind-options... I'll check in the evening when i get home.
If not, you could try to set smoothing in betaflight to "manual" and smoothing interval to 22ms.
What version of betaflight are you using?
EDIT: My mistake, checked my old dx6i... not sure if dsm2 modulation would be 11ms, and dsmx receivers should be backwards compatible. Maybe someone else knows. Anyway, there's still the option of manual 22ms smoothing in betaflight.
Also you wrote "latest firmware" on fc, i guess that means betaflight, not cleanflight, and latest would be 3.1.5.
That means roll and pitch should be smoothed by default, but not throttle and yaw.
To enable full smoothing on all channels, in CLI type "set rc_interp_ch = RPYT" and "save".
BTW rc smoothing is not about jitter, it's there for eliminating the steps in rc channels (see rc commands in your log, they look like stairs) which produce huge d-term spikes.
edited
Thanks for the support.My dx6i is post 2015 euro version so only dsmx 11ms protocol and no more selectable power output. Maybe corrupted binding? Where i can find the option of manual smoothing 22ms (or11ms?) on bf 3.1.5?
Ps:i am getting bored of "iPhone" philosophy of Spektrums. Dsmx,3.3v only sats ecc
#15
I found rc smoothing. I was looking in cli commands instead of receiver tab...
  Help Pitch axis oscillations and hot motors Extrm 0 311 08-Jul-2022, 07:54 PM
Last Post: Extrm
  Problem spike on roll ADRY 3 520 17-Oct-2021, 06:17 PM
Last Post: ADRY
  New Product DJI FPV with built-in camera LaserBrain 4 567 05-Mar-2021, 02:26 PM
  Motors Spin randomly / Quad not armed Seanalami 0 356 26-Jan-2021, 05:15 PM
Last Post: Seanalami
  Smallest quad for 2205 motors UrbanJungle1966 8 1,227 22-Oct-2020, 03:05 AM
Last Post: UrbanJungle1966
