I've tried three separate builds on one particular frame, and each time when powering up for the first time I've blown one of the ESCs. I've used (at least) two PDBs and FCs as part of this (might have repeated across two of the builds); each time it's been stripped all the way down. The only things constant to the builds are the motors and the frame. (Meantime I've done 7 other builds on other frames, none of which have problems.)
What steps do you go through in tracing a short circuit? I obviously don't see anything obvious. The PDB when unconnected to any ESCs is fine. The ESCs are insulated from the frame.
Also I'm a little confused by the shorted ESCs, or perhaps my multimeter. Switching the multimeter to 2k Ohms and running red to black / black to red on the ESC leads, I get about .550 on each ESC (which, if I'm interpreting it right, means there's a circuit through the ESC, i.e. non infinite resistance - right?) Should I expect to see any difference in a smoked ESC vs a non smoked ESC?
Finally, what does anybody use for quickly testing suspect ESCs? I now have a box of 12 suspect ESCs, 9 of which are probably good. I have an ESC tester (YKS servo tester / Turnigy thrust stand) but since I cut off ESC plugs when assembling that's a chunk of soldering time involved in each test. Is there an ESC testing rig with bulldog clips that'd make life easier for me?
