Field charging battery
Hi. I got a charger that takes in. I believe 12-38 volt dc. 2 question.
1.). Would a standard 12 volt car battery work to charge a couple 4S 1300 mAh 90c lipo batteries. Also how is this posible if 4S is more than 12 volt car battery.
2.) correct me if this is wrong.
If I connect a 24 volt DC battery to my lipo charger. This will be able to charge any 4S battery I have from 1300mAh to 5200mAh lipo. The 24 volt dc battery would be either a RV or marine battery.
12v or 24v will work fine. Your charger steps up the voltage for 4S or more.
[-] The following 1 user Likes Sugs's post:
  • Oscar
Cool thank you. I wasn’t sure how it worked since I don’t have experience in field charging
(04-Sep-2018, 07:13 AM)Sugs Wrote: 12v or 24v will work fine. Your charger steps up the voltage for 4S or more.
  Discussion 4-6s battery charger advice balauru_327 11 541 19-Feb-2024, 03:57 PM
Last Post: jasc
  Li-ion Battery and Betaflight mlcasmey 11 1,325 26-Jan-2024, 01:18 AM
Last Post: StuweFPV
  Discussion Battery Dimensions segler999 2 227 19-Jan-2024, 05:39 PM
Last Post: segler999
  XT-30 Charging Solution? drumgod 5 442 07-Dec-2023, 01:53 AM
  Help Need help with charging Runaround 7 2,428 13-Oct-2023, 10:48 AM
Last Post: lyoha
