Femto F3 is a new 20x20mm size brushless FC in the market.
20x20mm board
Weight 2.2 grams
Features
UART3 (RX3)
Use for Spektrum Satellite RX, Spektrum 1024/2048, SBUS, XBUS, SumD and SumH RX, etc.
UART2/PPM ‐ Serial RX or PPM RX + Telemetry
Use RX2 as PPM receiver. Use TX2 as telemetry output when using PPM
20x20mm board
Weight 2.2 grams
Features
- STM32F303 CPU
- MPU9250 accelerometer/gyro/compass (connected via SPI)
- 2‐6S LiPo battery
- Integrated 5V/3A BEC
- Dedicated Sbus and serial RX with 5v ,Spektrum 1024/2048, SBUS, XBUS, SumD and SumH RX with built‐in inverter, direct support 3.3v Spektrum Satellite receivers
- Telemetry support (frsky telemetry, smartport, and HoTT telemetry)
- Dedicated PPM receiver input
- Buzzer support
- Dedicated output for programmable LEDs ‐ great for orientation, racing and night flying. (Currently mutually
- exclusive with the Transponder)
- BLHeli Passthrough ready(connect BLheli suite)
- 2.0 mm pin headers
- 80A Current tolerance (PDB)
- Integrated Battery monitoring
- Use all the features all the time; e.g. Connect your USB + SmartPort + SBus + LED Strip + Battery Monitoring + 4 motors ‐ all at the same time!
UART3 (RX3)
