Posts: 21,248 Threads: 587 Likes Received: 8,962 in 6,632 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 787 14-Sep-2018, 09:23 PM (This post was last modified: 11-Oct-2019, 02:30 PM by SnowLeopardFPV. Edit Reason: Image links moved to imgur because tinypic closed down. ) This is a brand new $30 4S LiPo fresh out of the packet, never used (click to enlarge)... The supplier is issuing me with a refund but has told me not to bother sending it back. It's currently back in the ammo box along with all the others. I know what the sensible thing to do is. However it seems a bit of a waste to just bin it when it has 3 brand new perfectly good cells, but I'm fully aware of the dangers of these things. So the big questions are:- - Do I completely discharge it (not sure how exactly with it having a "bad" cell) and just dispose of it at a battery recycling facility.
- Do I cut off the shrink wrap and tape, and see if it can be repaired (maybe the balance connector wire for cell 2 just hasn't been soldered onto it properly).
- Do I try to make a 3S out of the 3 good cells (assuming cell 2 is actually bad and beyond salvaging).
If I try either 2 or 3 it would be outside well away from anything flamable with a fire extinguisher next to me. • Posts: 3,288 Threads: 129 Likes Received: 2,740 in 1,644 posts Likes Given: 2,969 Joined: Apr 2017 Reputation: 65 I would just remove the bad cell. I have two 3S packs that started life as 4S. As long as you do not short anything in the removal process, you will be fine. SoCal Kaity :D OMG, no one told me it would be this much fun! Addicted :) • Posts: 1,013 Threads: 11 Likes Received: 452 in 349 posts Likes Given: 372 Joined: Dec 2017 Reputation: 16 I would open it up and look for the problem as its easy to re-heat shrink or tape it up. If it's a bad cell then do like Kaity said and turn it into a 3s pack. • Posts: 3,533 Threads: 265 Likes Received: 2,610 in 1,545 posts Likes Given: 3,893 Joined: Feb 2018 Reputation: 78 15-Sep-2018, 01:51 AM (This post was last modified: 15-Sep-2018, 01:54 AM by Krohsis.) I agree with Sugs and Kaity.....mostly because you're so anal it will be done correctly....most others I wouldn't recommend it! As the recent memes are saying, Just Do It!! Besides, a house that doesn't smell like smoke is just silly.... Posts: 21,248 Threads: 587 Likes Received: 8,962 in 6,632 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 787 OK, you've all convinced me to take the "dangerous" option Of course, you know full well it will probably take me 6 months to actually complete this, so I'll report back in Spring 2019 with the results Posts: 3,288 Threads: 129 Likes Received: 2,740 in 1,644 posts Likes Given: 2,969 Joined: Apr 2017 Reputation: 65 SoCal Kaity :D OMG, no one told me it would be this much fun! Addicted :) Posts: 1,773 Threads: 30 Likes Received: 1,199 in 755 posts Likes Given: 714 Joined: Oct 2016 Reputation: 45 As said, it's pretty simple to do. But the question is , will you ever use a 3S?. No use taking the 1 in a million chance that you'll burn your house down for a battery that'll sit on your bench for 2 years then tossed. Dude, where's my quad? • Posts: 21,248 Threads: 587 Likes Received: 8,962 in 6,632 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 787 (17-Sep-2018, 01:38 PM)RENOV8R Wrote: As said, it's pretty simple to do. But the question is , will you ever use a 3S?. No use taking the 1 in a million chance that you'll burn your house down for a battery that'll sit on your bench for 2 years then tossed. I thought 3S was the way forward, no? Or was that 6S? I was never any good at maths If it can't be revived as a 4S (i.e. if the problem is just a broken balance lead wire) then a 3S battery could prove handy for use with a smoke stopper because it can be difficult to use a 4S battery for that without risk of blowing the 12v bulb unless it's pretty much depleted to its lowest safe minimum voltage. I've still not decided what to do but until I get issued with a refund (which hasn't happened yet), I won't be doing anything with it. Posts: 1,312 Threads: 50 Likes Received: 832 in 504 posts Likes Given: 372 Joined: Jul 2018 Reputation: 51 If you're taking it apart anyway then a 2S might be useful as a spare goggle battery. |
