27-Nov-2023, 09:27 AM
See if you wiggle the battery connector to the Hdo2, whether it turns off.
Fatshark hdo2 turns off at 7.8v |
27-Nov-2023, 09:27 AM See if you wiggle the battery connector to the Hdo2, whether it turns off. 27-Nov-2023, 01:28 PM It's strange that everything works from the PSU but not the battery. If it was a loose socket or failing solder on the barrel connector in the goggles it should behave the same from both the PSU and a LiPo. @OP - Does your PSU not go down below 5V? I find it odd that the screens never power off when powered from the PSU. Also, are you using the same barrel connection cable when using the PSU and a LiPo, or are they different cables? |
Burned MOSFET on Fatshark HDO2 | necbot | 8 | 552 | 13-Mar-2024, 05:03 PM Last Post: husafreak | |
Discussion Fatshark Dominator questions | 4 Inch Pistons | 12 | 1,100 | 15-Nov-2023, 05:14 AM Last Post: mstc | |
Fatshark HD3 gray-ish screen | Windky | 2 | 473 | 10-Nov-2023, 08:36 PM Last Post: Homada26 | |
Battery Requirements for Fatshark HDO2 and HDZero Module Setup | runfpv | 1 | 464 | 23-Jun-2023, 04:39 PM Last Post: Rob3ddd | |
black screens on hdo2 :-/ | hugnosed_bat | 5 | 419 | 31-May-2023, 09:38 AM Last Post: hugnosed_bat |
