Fat Shark lipo
Battery on my goggles does not seem to ever fully charge. I've left it on before upwards 90 minutes. The voltage just fluctuates around 8.20. The goggles also seem to die fairly quick. When I take the battery out and check the voltage it comes back barely half. Is it possible the cells aren't balancing?
Anyone reason I can't solder a 2.1 mm barrel connector to an xt60 and use one of my own 2s? Will the battery alarm on the goggles still work?
do you have a voltage alarm that reads 2S cell by cell? or just simply measure the voltage of each cell with your multimeter.
Yes you can modify the cable.. I did mine.
https://oscarliang.com/fpv-goggle-power-...connector/
I am using a 2S 1300mah pack, and it's A LOT better than the stock battery. I get nearly 3 hours from each charge.
  • K24cl9
Your tutorial is exactly what I am looking to do. I have some spare 2200 mah batteries I wanted to use
Never noticed this thread.
I'm using old rc car lipo, 2s 4200mAh, with a loooong wire so i can carry it in a pocket. Lasts forever, and ever, everever.
The Fatshark lipo is a very poor quality battery. Bought my goggles in june, and the battery has already puffed so the black lid has fallen off
  Tutorial ISDT SC-608 and SC-620 LiPo Charger Firmware Update Oscar 32 80,698 28-Feb-2024, 06:19 AM
Last Post: QuadSmack
  Discussion LiPo going up in smoke! swequad 15 693 07-Nov-2023, 07:34 AM
Last Post: BadRaven
  LiPO Voltage drop? william_hunter 5 441 03-Oct-2023, 06:19 PM
  Help Is my Lipo DEAD or charger DEAD ? Traxxrc1 6 766 08-Aug-2023, 12:32 PM
Last Post: stxrus
  Discussion a hypothetical LiPo question stxrus 3 416 17-Jul-2023, 02:36 PM
Last Post: stxrus
