F303 boot loader every boot
Hi guys maybe you will have some smart ideas what to check,
i have mounted the f303 board on a scrap xzmr, however the issue is that everytime i boot the fc (usb/battery alike) it enters boot mode...
i've uploaded new software, and after upload i can connect via betaflight config... issue is when i reboot... im again in boot mode...
what i have tested so far:
- uploaded newest betaflight 3.0
- uploaded betafligh 2.7
- checked with multimeter the "boot" buttton - when pressed there is a connection, when not no connection - so it works
at the moment i have 2 ideas:
- maybe one of ESC is sending some "stupid" signal
- board is crap (this piece)
All the best and formally hello as this is first post after few months of stalking Wink
Grzesiek
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
Why do you think it's in bootloader mode when start up? have you also tried "erase all settings" while flashing firmware?
Only blue led is showing up, in normal boot there is also activity led (red) blinking.
i've done full chip erase, and im able to reflash it as many times as i want. still until first reset... then im again in "blue" led only.
All the best
this sounds exactly like my dead Naze board.
Same I could flash a million times if I want, but it just stuck in bootloader mode. It was like that after some big soldering job, I reckon I burned something. Eventually I had to replace it.
Let the board rest for some time... today connected with usb... correct boot...
now "only" blue light is when i connect battery...
after short troubleshooting with Konrad.
he found that im a lazy person ... and i've connected rx/tx aiming for osd to uart 1 which is shared with usb... and when battery was connected 12v flew to vtx, 5v to osd... and we have a winner...
at the moment fc is booting all right every time.
All the best
(27-Aug-2016, 07:07 PM)Grisha0 Wrote: Let the board rest for some time... today connected with usb... correct boot...
hi  Grisha0 , i have almost the same problem , i  fitted a X_RACER v 3.1  to my quad running betaflight 3.0  yesterday  and for the first couple of goes it started fine and flew but after a few batteries every time i powered it up  a single blue light came on  and it did not make the right start up sounds , but if i plug in a powered usb first then plug in the battery  it powers up correctly  and will fly . i have no OSD . If you have any ideas i would be greatfull for some advice regards  jack
  Help FC not initialising on boot Vigilante_of_Light 3 1,319 05-Sep-2021, 12:55 AM
  Help Can't enter boot mode on f722 se Pierre 2 744 31-Jan-2021, 10:28 PM
Last Post: Pierre
  Broken Boot button on FC T18099 1 2,337 16-Dec-2018, 11:29 AM
Last Post: OverDischarged
  X-Racer F303 Board, LEDs in Cleanflight sher8256 22 10,164 07-Feb-2017, 08:26 AM
Last Post: alanwangwang
  X racer F303 V3.1 how to do 8K/8K? oyvinla 12 4,886 13-Dec-2016, 11:03 AM
Last Post: AndreyM
