Threads: 1
Likes Received: 0 in 0 posts
0 Hi there
Im new to the FPV world and after trying with the simulator i decided to get an E010s Eachine and im struggling to Flash it and bind it
Anyone has experince with this i cant even flash the board again...
any tips?
Threads: 672
Likes Given: 2,030
139 Need more info, what TX are you using?
what error are you getting in Betaflight configurator?
Threads: 50
Likes Received: 704 in 450 posts
Likes Given: 1,189
30 Regarding flashing, my usual suspects are 1) drivers, 2) bootpads, 3) "full chip erase" enabled...
But as Oscar said, more info would help.
Threads: 1
Likes Received: 16 in 10 posts
Likes Given: 1
2 I had similar struggles with an F3 brushed board. I spent hours trying to get it to flash, it was the most trouble I've had to date.
What eventually worked for me was to flash it with Zadig. I tried every bit of information I could find, nothing else worked.
Another thing to consider is that perhaps you have the target wrong. It doesn't say, explicitly, what the target is for the E010s. Are you still able to connect to the board? If so, connect to the board, go to the CLI, and type "version". That will tell you the correct target to be using, and you can confirm that you have that set correctly.
Threads: 0
0 Hi, Im new and also have little problem with my new E010S FrSky version.
When pushing button and connecting battery the blue led is still lighting but instruction said that blue led must blinkink fast.
When I powered without button the blue led is blinking slow.
How to turn FC to binding mode other ways?
FC is recognized and working under CleanFlight I can flashing and configuring the FC
Threads: 26
Likes Received: 354 in 189 posts
Likes Given: 8
13 I have spent a huge amount of time trying to work out the flashing of the F3 boards I have.
First there's a jumper to put it into "Flash" (or Bootloader) mode. But in that mode the Serial Port doesn't act the same as usual. So you (well I) need to use Zdiag to select the correct driver to use when it's in Bootloader mode. The instructions and tutorials (I don't generally YouTube ones, preferring text and screen shots) don't make as much sense as perhaps they could, so I fumble around until a "DFU" port mode comes up in Cleanflights serial port box on the top left of screen.
Then I can start the flashing process.
Don't forget to select the correct target types and all that.
At the end of all that magically only half the time my USB port reverts back to working normally triggering another round of wrestling with Zdiag so I can access the configurator.
Yeah.
Outright I'll say it. It sucks. Unfortunately for a lot of people this is either already a second-nature activity OR they have a PC hardware setup that's working a bit better with all this port type swapping and changing.
Threads: 0
0 on the other forum i saw solution to try and try and try and... then try... it's not a solution, it's not working and waste many time
how FrSky PPM8 ch must be set ? (my default proto PPM8 is 300uSec and FrLen 22.5mSec ald 1st Chan is set to 1)
I have Turnigy w/ er9x sw (and optional ext module FrSky)
I wrote an em@il to eachine but I haven't got answer yet... eh...
