F3 FC not recognized in computer
My brand new betaflight f3 board is not getting recognized by the pc it says
"the usb device you connected to the computer has malfunctioned and windows does not reconize"
i have all the proper drivers installed it will not even go into bootloader.
Reflash the board from bootloader mode. A messed up config will cause thus problem in some cases. Example: I accidentally enabled MSP on softserial last light and for some reason that made the USB not recognize the board.
https://youtu.be/Om6teCbJM4U?t=5m51s
also - this can happen if you accidentally flash the wrong target.. try that first before you go down the driver rabbit hole
  FPV remote won't connect to computer or DJI assistant software nicolomaserati 10 4,117 19-Mar-2023, 02:19 PM
  Iflight F7 , GPS not recognized dv1ne 0 392 13-Sep-2022, 11:04 PM
Last Post: dv1ne
  [ SOLVED ] Zeus13 AIO not recognized in Betaflight or Windows relentlesstech 5 497 21-Jun-2022, 06:32 PM
Last Post: relentlesstech
  Help fc not recognized by pc boldo 3 1,203 23-Dec-2021, 01:09 PM
  Help Revolt not connecting to computer Corasian 1 3,131 20-Dec-2016, 07:16 PM
Last Post: AndreyM
