F3 evo FC not binding to FrSky Taranis
Hi. I'm a beginner and can't seem to get my bnf micro fpv quad to work with the Taranis x9d+. It has the AC800 receiver which binds ok but the F3 evo FC won't arm. I can power the quad via betaflight but when i set receiver to SBUS it reverts back to Spektrum 1024 after hitting save & reboot. Any advice would be great.
could you confirm your BF version, and GUI version?
I think there has been some incompatibility between them in recently updates.
Update your FC firmware if possible also.
Do you have sBus selected in both receiver mode and serial receiver provider areas of the configuration tab? I've also had this problem when the correct UART isn't selected in the ports tab (If I remember it's UART 3 for the F3 EVO?)
(05-Aug-2017, 06:38 PM)Oscar Wrote: could you confirm your BF version, and GUI version?
Hi, Betaflight version I believe is preloaded with 3.2.0 as it's brand new. Don't know what GUI means.
(05-Aug-2017, 07:37 PM)RENOV8R Wrote: Do you have sBus selected in both receiver mode and serial receiver provider areas of the configuration tab?  I've also had this problem when the correct UART isn't selected in the ports tab (If I remember it's UART 3 for the F3 EVO?)
HI. Yes SBUS in receiver and config tab. Says to switch on serial rx in uart2 tab tho not uart3?
(05-Aug-2017, 09:17 PM)Kev Wrote: Hi, Betaflight version I believe is preloaded with 3.2.0 as it's brand new. Don't know what GUI means.
The GUI is the betaflight configurator (BFC) (chrome app). With betaflight firmware 3.2 you will need the latest GUI aka BFC to properly configure.
I am not sure if older firmware will work with the newer BFC.
(08-Aug-2017, 05:45 AM)voodoo614 Wrote: The GUI is the betaflight configurator (BFC)  (chrome app). With betaflight firmware 3.2 you will need the latest GUI aka BFC to properly configure.
Hi. I copied this off my Betaflight. 2017-08-13 @ 12:32:35 -- Running - OS: Windows, Chrome: 60.0.3112.90, Configurator: 3.2.1
I managed to flash the FC as it had last yrs version on it. It all works up to where I try to arm it and it does nothing. I have configured an arm switch on the TX and it shows operating on BF, I also have the sticks interacting with BF too. Just don't understand why it won't run off the TX Sad
Hey Kev, I hope you solved your "... I try to arm it and it does nothing." issue. If not, see if adjusting the " 'Stick Low' Threshold", as described below, solves the problem for you. It did for me. I came upon your thread when I experienced the similar "... set receiver to SBUS it reverts back to SPEKTRUM 1024 ..." behavior on my quad.
Some background information ... I bought an F3 EVO FC equipped brushed quad with an AC800 Rx in December 2016. The FC was flashed with "BetaFlight/SPRACINGF3EVO 3.0.1 Oct 18 2016 / 10:36:44" (BetaFlight: Board SPRACINGF3EVO) . I had been using the Chrome based BetaFlight Configurator (BFC). All was working well. The "... SBUS reverts back to SPEKTRUM 1024 ..." behavior occurred after I upgraded to the Windows based BFC (10.1.0). Flashing the FC with the latest available BetaFlight FW (Flight controller info, identifier: BTFL, version: 3.2.4... -- Running firmware released on: Jan 10 2018 23:10:00) solved that problem. At this point, I have not restored the rate profiles (should not be too difficult by cut&paste of the CLI dump I made) but it is flying again.
I had the same "everything appears to work in BetaFlight but motors will not arm" behavior. I noticed that my throttle range (BetaFlight 'Receiver' tab; when Rx is bound and Tx is on) did not span the 1000-2000 (centered at 1500). I adjusted the " 'Stick Low' Threshold" (which was set below the lowest point of my throttle range) to be above the low end value of the range. Now the motors arm.
I also adjusted the "Stick Center" to the value that appears to be consistently at the mid point of throttle when the stick is at 50% travel. I will play with the Tx 'Outputs' (see below) as well going forward.
I know how to adjust the BetaFlight Rx ranges (and center point) using the OpenTX 'Outputs' on my Taranis X9D (so the BetaFlight values span the 1000-2000 range & center at 1500) when the Betaflight range values are outside (<1000 min & >2000 max) the 'normal' range but I don't know how to 'widen' the BetaFlight Rx range when these show as >1000 min & <2000 max.
Interesting that the min throttle drops to 885 when in failsafe.
Any who ... hope this helps.
Keep your (prop) tip ends clean! My Tx is calling "Inactivity alarm!"
  Zeus AIO F411 binding, but not(?) tonysnewdrone 3 407 11-Aug-2023, 04:01 AM
Last Post: Lemonyleprosy
  Help crux35 crazyf411 frsky failsafes after ~1min robbfox11 0 151 28-Jul-2023, 02:56 AM
Last Post: robbfox11
  Omnibus F4 V3 + frsky r-xsr = nightmare nintendude7cubed 59 17,188 27-Jun-2021, 10:49 AM
Last Post: resettik
  MATEKF405CTR and FRSKY XRSB lleston2 19 1,951 16-May-2020, 03:42 AM
Last Post: lleston2
  Use of FC 405 with FrSky Receiver but no Tx MartinH 6 691 15-Apr-2020, 02:54 PM
Last Post: MartinH
