Threads: 1
Likes Received: 0 in 0 posts
0 hi my board wont arm after a nasty crash, the Accelerometer seems dead i tried to disable it with the "set acc_hardware=none" command but for some reason it wont let me arm.
i have checked my radio is inside the ranges, and i have set the "set small_angle=180" as suggested by someone so that i would be able to arm at any angle.
am i missing something, or did the flightcontroller die?
sorry for the newbie question : )
Threads: 67
Likes Received: 713 in 473 posts
Likes Given: 1,216
23 You say it won't arm.....you sure you've got power to the board? If you know there is power to it, does it beep three times when you set it on a level surface (indicates the gyro has calibrated)?
Threads: 50
Likes Received: 704 in 450 posts
Likes Given: 1,189
30 Could it be the gyro is broken? If it can't initialize properly, you can't arm i think.
Not sure there is a command to run gyro test from CLI... ?
Threads: 51
Likes Received: 1,861 in 1,175 posts
Likes Given: 3,315
74 Does the receiver tab in Clean/BetaFlight indicate proper motion and range when you move your sticks? You might also try to arm with failsafe disabled. For some reason, I am suspecting a receiver problem.
Threads: 12
Likes Received: 38 in 24 posts
Likes Given: 1
1 That means your gyro is probably dead. You can try smacking the board against a table, maybe that makes it work again (no kidding, that fixed my phone's gyro)
