Extend Motor Wires?
I have finished EVERY part of my build except soldering the motors to the ESC's. I have tested everything in cleanflight to make sure I get the expected results and it all looks good (motors excluded obviously). The reason I have not soldered them yet is two fold.
I want to use bullet connectors for the motors for quick swap capability in case I blow/damage an ESC or motor someday.
The motors also came with relatively short wires which do not reach properly with my frame.
What wire should I be buying for this and where should I buy it from? I went to Lowes & Menards and neither seemed to have what I needed.
I am using 25A BLHELI.S ESC's and Racerstar BR2205 KV2300 Motors.
THANK YOU!!!
It's a bird... It's a plane!... It's Oscar to the rescue again!
Quadcopter wire guide
The Obsession IS Real!
(30-Apr-2017, 09:30 PM)Drone0fPrey Wrote: It's a bird... It's a plane!... It's Oscar to the rescue again!
Lol Smile
I was reading that article actually right before i posted this. Based on that I should be using about 22AWG however I can not find any places to buy stranded wire except in BULK and I mean like industrial BULK. So I thought I might be calculating it wrong. Is there a reliable place to buy this kind of wire?
eBay.
Search for "silicone insulated cable".
  • Drone0fPrey
(30-Apr-2017, 09:53 PM)unseen Wrote: eBay.
Searching silicone wire or silicone cable brought up what I needed! Thank you. I had been just searching for 22agw wire or 22agw cable and it was not what I needed. Thank you.
[-] The following 1 user Likes aziassassin's post:
  • unseen
  Transitioning from 4s to 6s: Motor KV and Props Relationship soldierace 4 72 Yesterday, 09:03 PM
  Motor KV Eyes.fpv 10 187 11-Apr-2024, 03:02 PM
Last Post: BadRaven
  T-Motor F7 HD is not powering rbarac 1 84 06-Apr-2024, 11:51 PM
  4 inch frame with 16x16 motor mounting holes Pathfinder075 10 200 19-Mar-2024, 07:02 PM
Question Motor short question FeuerKai 12 396 28-Feb-2024, 06:36 PM
Last Post: mattyfleischfpv
