ex110 and taranis x9d
Hello,
Very new to the hobby, I have an eachine EX110 with a frysky receiver and a Taranis XD9.  I have no idea how to bind or use them together.  Any help would be appreciated.
On the Taranis, go to model setup. Scroll down to [BIND] and select that. Radio should start beeping. Now that you are in bind mode, on the ex110, the frsky receiver should have a button. Hold that button down and plug in the battery. Usually a solid green light and blinking red light means it is bound. Unplug battery. Push enter again on Taranis to get out of binding mode. Plug the battery back into ex110. You should get a solid green light if successful bind.
I don't have an ex110, so I can tell you for sure the lights sequence is the same. The other thing is, you have to pick the right receiver mode prior to binding. I assume it will either be D8 or D16.
Anyway, here is a link that might be helpful. Good luck.
https://www.rcgroups.com/forums/showthre...?t=2750532
  • sloscotty
  Taranis x9D plus output?! Rob Axel 14 159 15-Apr-2024, 07:26 PM
Last Post: SeismicCWave
  FrSky R-XSR not binding with Taranis QX7 ACCST Pete10 6 241 26-Dec-2023, 06:06 PM
  Taranis xlite + TBS crossfire/NanoRx issue Klingus 2 282 19-Sep-2023, 07:15 PM
Last Post: Klingus
  Taranis X9D+, Crossfire Nano, SpeedyBee F7V3 - No input (stick movement) detected reallyslick 3 498 17-Apr-2023, 01:28 AM
Last Post: reallyslick
  HELP taranis qx7 jgriz99 14 1,238 19-Jan-2023, 05:06 PM
