Threads: 3
Likes Received: 0 in 0 posts
Likes Given: 0
0 Still working on my first build. I am using DYS 16a ESCs and DYS 1806 motors. The first time I plugged in a lipo 3s battery, 2 of my ESCs smoked out. So I replaced them with 2 new ones and no smoke. After some testing of motors through Cleanflight and USB cable, another esc and motor smoked out. So I ordered new ones.
The other day I got my replacement ESC in the mail, so I flashed all 4 with BLheli & blheli bootloader (had to use the file for 20 amp since there was no 16 amp). Tonight I plugged in the quad to a lipo and one of my previously good ESCs (nothing changed on this one) went up in a little smoke and some heat, and caused the motor to smoke out also. I immediately unplugged the lipo and checked continuity between positive and negative on the PDB, and I had it. Had to unsolder everything from the PDB one by one and found the short between positive and negative in the smokey ESC.
Are these ESCs really that touchy? Am I doing something wrong? Need help.
Threads: 2
Likes Received: 66 in 45 posts
Likes Given: 27
17 12-Feb-2016, 07:22 AM (This post was last modified: 12-Feb-2016, 07:24 AM by AndreyM.) These ESCs are tiny and vulnerable to soldering imperfections, especially the so-called "solder balls" which look like, surprise, small balls made of solder.
Most respectable members of community suggest thoroughly checking both sides of PCB for possible shorts by aforementioned solder balls before using the ESCs for the first time.
There also been numerous reports about DYS ESCs failing miserably, but the exact problem is unknown. May be a drop in production quality.
Just my 2 cents here :-)
Threads: 3
Likes Given: 0
0 When I first got the original motors wired up, I tested them via CleanFlight and spun them fast. I have since learned that this is a no-no. How can I test the motors to make sure they aren't bad and the culprit for my burning ESCs???
Threads: 672
Likes Given: 2,030
139 sounds like there is a fault in the build, or your ESC is just fault, might be worth recording it next time you plug things in ...
I have never seen anyone burn so many ESC and motors the first time they plug them in...
Threads: 2
Likes Given: 0
0 I have 8 DYS 16A esc and none of them have given me any trouble. I took a chance and bought them from hobbyking for their small size despite reading about problems with them. Still, they shouldn't give you this kind of trouble. Either you have the worst of luck and got some escs from the bad quality batch or you have a short circuit somewhere.
Are you using a carbon frame and the escs are in contact with the frame somewhere? That could result in the shorts.
BR,
Henrik
Threads: 3
Likes Given: 0
0 I am using a carbon fiber frame and a full size pdb (UBAD Kunai v2). Should I be putting some sort of plastic washers between the frame and posts, and the PDB and posts?
What kind of test could I do with my multi-meter to see if I have current running through my frame or posts?
Threads: 672
Likes Given: 2,030
139 Post some pictures of your build, your ESC / motor soldering please so we can advise on how you can improve it or prevent problems.
