esc/motor problem
Ive been working on my first custom built quad copter using an arduino and im having problems with 2 of my esc's. i connect them to the battery and motor but i can barely hear the beeps and after calbrating it i can slightly hear a current going through the motor but its very small. i checked the voltage output of the esc using voltmeter but it barely picked up any voltage but once the motor was removed the volt would spike just like it should when it makes the motor beep. the other 2 esc's work fine and they are the same type as the other 2 that arent. does anyone know how to fix this or if i need to get a new esc's? my specs are.
11.1V 3s lipo battery
20amp 6-16.8V esc
1000kV motor
  Help TMotor F55 Pro ii ESC won't power FC after crash EyeBotXander 2 240 11-Apr-2024, 09:32 PM
Last Post: EyeBotXander
  Solved ESC and FC rebooting during motortest zsolth 5 112 11-Apr-2024, 01:34 PM
Last Post: zsolth
  Sometimes a motor surprises you - in a good way mstc 20 766 10-Apr-2024, 09:00 PM
  Help Brother Hobby Motor VY1507 hawk01 3 88 05-Apr-2024, 07:58 AM
  Help Mobula 8 after crash motor ramp up to max with minimum throttle johnny1234 7 900 31-Mar-2024, 05:43 AM
Last Post: spiralthomas
