25-Jun-2017, 08:34 PM
When installing ESC on the frame, should I remove heatshrink from the ESC's or leave it on?
ESC heatshrink: keep or remove? |
25-Jun-2017, 08:34 PM When installing ESC on the frame, should I remove heatshrink from the ESC's or leave it on? 25-Jun-2017, 08:38 PM Shrink-wrap covering is important to isolate components from carbon which is ground. Always use heatshrink for your ESC if installing on the arms. True in general, but heatshrink per se is not necessary. Always insulate any electronics from carbon, but heatshrink is not necessary. You may use a foam pad, you may conformal-coat the whole ESC or do something similar. Removing heatshrink may improve thermal profile of your ESCs. |
Help TMotor F55 Pro ii ESC won't power FC after crash | EyeBotXander | 2 | 266 | 11-Apr-2024, 09:32 PM Last Post: EyeBotXander | |
Solved ESC and FC rebooting during motortest | zsolth | 5 | 118 | 11-Apr-2024, 01:34 PM Last Post: zsolth | |
Solved Cannot connect ESC | derange | 2 | 145 | 22-Mar-2024, 10:05 PM Last Post: derange | |
Solved Cannot recognise 1 Esc at 4in 1 Esc | Mad35 | 11 | 216 | 12-Mar-2024, 01:47 PM Last Post: Pathfinder075 | |
Help ESC working but motor not spinning | Prashant1901 | 1 | 145 | 10-Mar-2024, 02:09 AM Last Post: Pathfinder075 |
