16-Nov-2016, 10:27 PM
Why would changing from a 3 to 5 blade prop make one esc cut out when i punch it? Does it have to do with the blades, or did i mess somethin else up?
ESC failed with increasing prop blades |
16-Nov-2016, 10:27 PM Why would changing from a 3 to 5 blade prop make one esc cut out when i punch it? Does it have to do with the blades, or did i mess somethin else up? 16-Nov-2016, 10:30 PM 5 blade prop would be pulling a lot more current (amps), especially if your referring to those racekraft pentablades. Too high Amp draw and overheating = thermal shutdown or what blheli suite temp protection. Temp protection enabled will save the esc but it will shutdown if temp reaches a too high of value. And by the way, personally, I think 5 blades are just a joke, even 4 blades are pushing it too much. |
Help TMotor F55 Pro ii ESC won't power FC after crash | EyeBotXander | 2 | 244 | 11-Apr-2024, 09:32 PM Last Post: EyeBotXander | |
Solved ESC and FC rebooting during motortest | zsolth | 5 | 112 | 11-Apr-2024, 01:34 PM Last Post: zsolth | |
Solved Cannot connect ESC | derange | 2 | 138 | 22-Mar-2024, 10:05 PM Last Post: derange | |
Solved Cannot recognise 1 Esc at 4in 1 Esc | Mad35 | 11 | 214 | 12-Mar-2024, 01:47 PM Last Post: Pathfinder075 | |
Help ESC working but motor not spinning | Prashant1901 | 1 | 143 | 10-Mar-2024, 02:09 AM Last Post: Pathfinder075 |
