Threads: 30
Likes Given: 714
45 Yes, they'll be fine. I've seen basically the same setup running 3S with no problem.
Threads: 10
Likes Received: 3 in 2 posts
Likes Given: 19
1 Thanks I'll pick up some escs soon.
Threads: 3
Likes Received: 13 in 9 posts
Likes Given: 1
0 Have you got your reciever yet? Just a heads up if you have any drop outs with it I had the same problem. There's a fix which is to wrap it in foil to shield it from RF interference and it worked great. Not sure if they have fixed the issue in the new batch.
Threads: 10
Likes Given: 19
1 I have 2 fs a8s in two other models and havent had an major issues. I have noticed sometimes when i first power on my quad and then take off there will be a delay in the input but then about 10 seconds it gone and flies no issues. I thought it was the receiver but i tried two did fs a8s on two different quads and the same thing. Thanks for the info though i might try that with this build.
Threads: 3
Likes Given: 1
0 I was having an issue on my KK 90gt where if I go about like 75% throttle it would hold that throttle position for a second or two after I brought the throttle back down. Made it feel like the reciever was almost lagging. There's a big forum on RCGroups with flysky rep talking in it and all. They know of the issue and have been trying to fix it but idk if it has been fixed yet. Other than that I like the reciever it's been good.
Threads: 10
Likes Given: 19
1 I hopefully they do fix the issue. Luckily i havent had any majors issues.
