esc amp question
Question
Hey guys im working on a new build and had a noob question. Im going to use the 4 blade gemfan 2035 props with racerstar 1103 8000kv motors. I only ever used 2 blade props till now. My question is that is a 6amp escs enough for this setup. Trying not to over prop. Im only going to be running on 2s. Huh
Heres the list of all my parts so far
x2 elf frame
gemfan 2035 props
fs a8s reciever
tx01 AIO
Thanks in advance
Yes, they'll be fine. I've seen basically the same setup running 3S with no problem.
Thanks I'll pick up some escs soon.
Have you got your reciever yet? Just a heads up if you have any drop outs with it I had the same problem. There's a fix which is to wrap it in foil to shield it from RF interference and it worked great. Not sure if they have fixed the issue in the new batch.
I have 2 fs a8s in two other models and havent had an major issues. I have noticed sometimes when i first power on my quad and then take off there will be a delay in the input but then about 10 seconds it gone and flies no issues. I thought it was the receiver but i tried two did fs a8s on two different quads and the same thing. Thanks for the info though i might try that with this build.
I was having an issue on my KK 90gt where if I go about like 75% throttle it would hold that throttle position for a second or two after I brought the throttle back down. Made it feel like the reciever was almost lagging. There's a big forum on RCGroups with flysky rep talking in it and all. They know of the issue and have been trying to fix it but idk if it has been fixed yet. Other than that I like the reciever it's been good.
I hopefully they do fix the issue. Luckily i havent had any majors issues.
  My TP3 and a 1S-3S DarwinFPV board question drumgod 15 823 01-Dec-2023, 11:29 PM
Last Post: drumgod
  BND Hummingbird F4 v3 ESC dead? klnyc 5 415 28-Sep-2023, 06:02 PM
Last Post: lyoha
  1002-20000kv 1.6" props too much for a 5A ESC? Flywoo Firefly Nano Baby 1S mstc 7 556 23-Sep-2023, 01:16 AM
  Mobigital 7 ESC what f/w to use ? niuk 1 177 17-Aug-2023, 08:30 PM
Sad Help GEPRC CINELOG 25 - MOTOR/ESC DESYNC? skareb 4 386 13-Aug-2023, 09:01 AM
Last Post: Lemonyleprosy
