01-Mar-2023, 05:05 PM
Hello, could you give me some advice? I assembled the drone, everything actually works, but I have a problem with the throttle. If I try the engines through Betaflight, everything runs ok. As soon as I disconnect the Beta and connect the battery and try to add throttle, my engines start to jerk... If I try the levers on the radio in any other way (yaw, pitch, roll) calmly at full speed, everything runs perfectly fine, but a little throttle and there is a problem. .. I have a speedybee f405 V3 board, emax eco ii motors, frsky archer receiver. The same problems with proppelers on in the air. Tried mulitple pid tunnigs but none works. https://youtube.com/shorts/co8ExO1auLc?feature=share
Have BF 4.4 and Bluejay
Thanks a lot, Michal
