Enable Blackbox logging whilst not flying
I have an SPRacing F3 EVO board and i want to test the gyro sensors on the bench with just a battery connected. However to enable Blackbox logging CleanFlight/BetaFlight require that the system be "ARMED". Is there a way to fool the system into thinking it is armed just for testing purposes? I hope to compare multiple boards at the same time so want to do it all without having to arm the systems with a radio.
You can arm the quad on the bench, just enable "motor stop" and disable air mode Smile
why not do it with the props off?
(19-Jan-2017, 06:28 PM)Oscar Wrote: You can arm the quad on the bench, just enable "motor stop" and disable air mode Smile
Thanks - I tried your suggestion but it does not seem to activate the Blackbox logging. The only way I can get it to log on the bench is to go through the GUI and manually activate the motors in Motor Test Mode - this activates the logging. What I would like is to just plug in the battery and for it to start logging automatically without having to go through the GUI. I have included the informative parts of the dump file below:
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -OSD
feature -BLACKBOX
feature -TRANSPONDER
feature -AIRMODE
feature -SDCARD
feature -VTX
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature RX_PPM
feature VBAT
feature MOTOR_STOP
feature GPS
feature FAILSAFE
feature CURRENT_METER
feature RSSI_ADC
feature BLACKBOX
feature SDCARD
# map
map AETR1234
serial 2 2 115200 57600 0 115200
# master
set task_statistics = ON
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rc_interpolation = AUTO
set rc_interpolation_channels = RP
set rc_interpolation_interval = 19
set rssi_ppm_invert = OFF
set max_aux_channels = 6
set debug_mode = NONE
set min_throttle = 1070
set max_throttle = 2000
set min_command = 900
set digital_idle_percent =  3.000
set 3d_deadband_throttle = 0
set use_unsynced_pwm = OFF
set motor_pwm_protocol = ONESHOT125
set motor_pwm_rate = 400
set disarm_kill_switch = OFF
set small_angle = 25
set fixedwing_althold_dir = 1
set gps_provider = UBLOX
set gps_sbas_mode = EGNOS
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set beeper_inversion = ON
set beeper_od = OFF
set sbus_inversion = ON
set spektrum_sat_bind = 0
set telemetry_switch = OFF
set telemetry_inversion = ON
set sport_halfduplex = ON
set frsky_default_lattitude =  0.000
set frsky_default_longitude =  0.000
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set pid_values_as_telemetry = OFF
set ibus_report_cell_voltage = OFF
set battery_capacity = 0
set vbat_scale = 110
set vbat_hysteresis = 1
set current_meter_scale = 400
set current_meter_offset = 0
set current_meter_type = ADC
set battery_meter_type = ADC
set battery_notpresent_level = 55
set use_vbat_alerts = ON
set use_consumption_alerts = OFF
set consumption_warning_percentage = 10
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_yaw = 0
set gyro_lpf = OFF
set gyro_sync_denom = 8
set gyro_isr_update = OFF
set gyro_use_32khz = OFF
set gyro_lowpass_type = PT1
set gyro_lowpass = 90
set gyro_notch1_hz = 400
set gyro_notch1_cutoff = 300
set gyro_notch2_hz = 200
set gyro_notch2_cutoff = 100
set moron_threshold = 48
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set yaw_control_direction = 1
set yaw_motor_direction = 1
set servo_center_pulse = 1500
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400
set servo_pwm_rate = 50
set gimbal_mode = NORMAL
set airmode_activate_throttle = 1350
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set acc_hardware = AUTO
set acc_lpf_hz = 10
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf =  0.600
set baro_cf_vel =  0.985
set baro_cf_alt =  0.965
set baro_hardware = AUTO
set mag_hardware = AUTO
set mag_declination = 2470
set pid_process_denom = 16
set blackbox_rate_num = 1
set blackbox_rate_denom = 16
set blackbox_device = SDCARD
set blackbox_on_motor_test = ON
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
set sdcard_dma = OFF
Are you trying to do this without using your transmitter? I don't think it will "arm" without a Tx signal (I suspect the motor tab provides the "signal" when connected to betaflight) . Seems like it could work if you arm via switch on the Tx and just leave the throttle alone.
(19-Jan-2017, 11:58 PM)sloscotty Wrote: Are you trying to do this without using your transmitter?  I don't think it will "arm" without a Tx signal  (I suspect the motor tab provides the "signal" when connected to betaflight) .  Seems like it could work if you arm via switch on the Tx and just leave the throttle alone.
@sloscotty thanks for the suggestion. Yes I'm trying to do this without a transmitter - literally just a board and a battery is the goal. I was wondering if there was a hardware hack (ie solder a across something) that would provide the arming signal?
Maybe you could set the arming switch as always on in the modes tab? I haven't tested this myself, so I don't know if it will work
(20-Jan-2017, 02:01 PM)oyvinla Wrote: Maybe you could set the arming switch as always on in the modes tab? I haven't tested this myself, so I don't know if it will work
This might work.  I just tested a Piko BLX and it shows Aux 4 is getting a signal with only USB plugged in (no Rx attached).  And it shows armed when I set the switch - but that's still with USB plugged in.  (I don't if any of the Aux channels would get a signal with only battery though - worth checking.)
CLI  =
set blackbox_mode = ALWAYS
save
Star What are you flying now? Share your drones samysh 10 435 21-Jan-2024, 04:52 PM
Last Post: iFly4rotors
  My drone spins out of control but i can't see anything on the blackbox Smoses221 4 330 01-Mar-2023, 12:46 PM
Last Post: Smoses221
  First Build Complete and Flying! C17MooseLoad 6 511 08-Dec-2022, 01:23 PM
  Blackbox Help tacomaty 3 365 07-Dec-2022, 01:36 PM
Last Post: Oscar
  Can you enable bidirectional dshot on any BlHeli32 ESC? Egg_FPV 1 1,858 01-Dec-2022, 07:28 AM
Last Post: kafie1980
