Threads: 25
Likes Received: 8 in 6 posts
Likes Given: 3
1 Hey guys, I got a set of EMAX RS2205 2600KV.
I only ordered CCW, thinking that they can run in either direction like most of my other motors.
Well the two running CW are getting crazy hot very quickly, under a minute of hovering. Any ideas?
I am running LittleBees 20A, BLHeli 14.4, tried BetaFlight and CleanFlight.
Threads: 672
Likes Given: 2,030
139 Another incidence of motor screws touching windings?
If that's not the case, try switching them around and see if the other 2 get hot. The ccw/CW just means the thread on the prop shaft, should still work the same and interchangeable.
The following 1 user Likes Oscar's post:1 user Likes Oscar's post • Mish Posts: 2
Threads: 0
Likes Received: 0 in 0 posts
0 29-Apr-2016, 11:43 AM (This post was last modified: 29-Apr-2016, 12:19 PM by cgo.) i have the same problem and made sure that the screws are short but after some 5 minutes of 4S batteries, all the motors appears to be very warm. is this normal?
for additional info, I am using the new LittleBee Pro 20A which I believe should be sufficient for the emax RS2205?
