Review of Emax Nighthawk PRO 200
We received great shop Belgian ERC MARKET a copy of the RTF small race drone made by EMAX.
Little time for pub ERC MARKET that us anyway generously.
**** **** JINGLE START
Be sure to drive to the point of sale located on the side of Overijse in Brussels entrance, a dynamic and terribly friendly will welcome you.
If you live too far away or do not have time to visit the point of sale, know that they have an online webshop very well furnished and full of novelties at competitive prices .. to discover or rediscover !! !
**** END **** JINGLE OF
Technical characteristics
Emax 200 Nighthawk Pro PNP FPV Racing Drone ready to bind comes with BetaFlight Installed.
Fpv Camera, RS2205 Race Motors, VTX, LEDs, and Props. A great kit for getting into the racing drone scene.Features Highlight
The Nighthawk Pro Racing 200 Drone PNP, comes installed with the latest in racing technology drone, it Allows new pilots in the hobby Progressively to fly like the professionals. The Nighthawk Pro 200 features a great price, amazing value, and technology Compared To competitor's products.
- Race motors ready right out of the box. The RS2205 motors Are The Champion's choice for competition. Now you can get the best!
- Modular design with the Ability to switch out components without HAVING to hand to solder small connectors.
- Full LED coverage to help gauge orientation in the brightest and darkest of days of nights.
- Easy access to the port switch off motor mount LEDs
- Plastic molded motor guards and bottom shell for Increased durability and protection of electronics in the event of a crash.
- High quality 3k Carbon fiber mainframe for maximum structural integrity.
- CCD Camera for high quality picture through FPV.
- Adjustable for different lighting conditions.
- 25-200mw switchable Video Transmitter with 48 Channels of frequency.
- Digital LED display for easy view of current channel setting.
- Integrated Power Distribution Board (PDB) to supply regulated power for all electronic components.
- 2mm Socket Button Head Screws are standard.
- Adjustable camera mount to follow faster (high angle camera) gold more steady (low angle camera) Flights.
- Top cover to Accommodate an HD camera.
unboxing
The unboxing will be quick as it comes in a super convenient carrying pouch, which will protect perfectly.
The cover, down ERC MARKET shelf itself was packed in a transparent plastic film .. but as we were eager to discover the craft I have not made the first picture: p
The black box, but relatively stiff fabric, in which lies the NightHawk, surrounded by a red zipper .. the colors of the brand.
The zipper is opened incidentally exudes quality.
We discover the manual MUST READ !!! (as all manuals what ...)
Under the manual, we find a bag in which is located the propellers.
Yellow bladed ... that will go perfectly with the look of the beast ... you'll see further.
The bag is moved gently ... too eager to find out what's underneath.
Tadaaa the ......
On the right side, packed in a small bag is an antenna Emax Pagoda (new hype).
Remember to place the antenna on the machine connect BEFORE lipo otherwise you're likely to say bye bye to your video transmitter.
We look at what's underneath?
Nothing: p
But notice the wide area dense foam that will protect your baby during transportation ... In there he will fear nothing.
Located in the lid, a zippered pocket is also available to store some small not too bulky objects as allen key, a USB cable and manual.
Speaking of the little pouch, this is what was in it.
A small zip pouch containing the USB cable, Velcro double sided and a control cable for the camera OSD.
Overview
I suggest we look at all this in more detail and depth.
Overall it has the mouth!
Front View, in her yellow dress it imposes even if it is a small format.
Side view, notice the few openings. At least we will not spend our time cleaning up after a bit messy session. A shot of rag will suffice to restore its original luster!
The top plate of the machine, while carbon is smooth and soft to the touch like the skin of a baby.
View from the other side, as the webbing there is the USB port to be used for the configuration as discussed a little later in this article.
On the top of the unit, located toward the front of the machine, behind the camera, is a "servo" type of card on which will connect your remote control receiver. We find it in the standard order: black = gnd, red = + 5v, orange = sbus / ppm.
On the back of the device are located two transparent blocks which each contain a programmable LED RGB via your betaflight or cleanflight interface.
You can choose your color on the back to slightly customize
Between the two LEDs are small holes hiding a buzzer that can be assigned to a switch (again in betaflight interface or cleanflight) to the trigger to locate the buzzer ... it will also serve to warn you of low battery voltage or to report another malfunction of the flight map.
Also on the rear of the machine, near the passage of power cables with the XT60 on which it will connect the battery is a little red cap.
Under this red cap is located SMA connector antenna (especially not to forget to fit before connecting the battery).
Are also visible, near the antenna connector, a small display will inform the channel and the frequency band on which rests the video transmitter (left in the picture) and in front of this display is a small button that will change the channel or frequency band (on the right in the photo).
You can easily change the channel to tune with other pilots when flying to many.
The video transmitter is configured original 25mW in order to comply with European standards, but you can easily switch to 200mW ... for that you will have access to the interior of the drone and this switch a microswitch on the side of the video transmitter.
On the left side of the drone in the part in yellow plastic abs, is the Micro USB connector that will set it up under betaflight (note that it is also compatible cleanflight).
The betaflight application is available in the Google Chrome browser.
View the superb, well known for their performance and powerful engines EMAX RS2205!
With this combo engines and propellers 5050 bullnose you will not lack power.
In 4S that promises to send !!!
Under the engine section is placed a semi-transparent plastic part which partially surrounds the engine to protect the shock; in addition it also includes LEDs that illuminate your multi after his 4 arms.
Small flat is the passage of motor cables through the carbon arms. I fear that with time and crashes carbon does come sever or cut the sheath of the cable short circuit, which will cause a destruction of the connected esc.
The CCD camera is integrated in a kind HS1177 ABS case yellow for integration with the look of the drone.
The camera is placed on a hinged support (red) which allow you to give the angle right for your type of flying.
Straight ahead to the promenade, with great inclination to race or aggressive flights.
We return the creature like a turtle on its shell to analyze its shell abs flashy yellow .. With this one, you will not risk to miss during a search following a crash; combined at the buzzer and LEDs it will be just perfect!
The hull is quite smooth, only a few openings are created for the cooling of the ESC for the USB port or to a microswitch to disable the LEDs under the engines, located on the forearm, near the cooling rack esc the side of the uSB connector.
You may wonder if the hull is solid and will bear crashes !? It is sufficient to absorb shock, support standard crashes during the sessions, but surely not resist a concrete column at a session in parking lot: p
The end of the arms, under an engine, transparent plastic which allows distinguishing two high brightness LEDs that illuminate the device to distinguish orientation. Note that the LEDs under the engines are not programmable!
The antenna supplied to the video transmitter is a pagoda-type antenna version 2.
At present this is what is best in terms of reception quality, signal coverage in the video antennas 5.8GHz .
The antenna is provided in SMA connectors.
View bladed propellers 5050BN transparent yellow.
With that it is certain that we will have a fishing LOT!
A 200 .. From 5 ".. It happens? That's right, but this combo works perfectly
In the belly of the animal.
To open the belly of the beast that is super easy .. Simply unscrew the 6 screws in allen size: 2 on the back on top of the unit next to the video transmitter and 4 located below at the front in the camera which can release it and its support .. Then exert a slight pressure on the plastic shell to release it as it crept 2mm beneath the transparent substrates.
The thickness of the carbon is about 3.6mm which ensures rigidity, robustness, while remaining lightweight.
Is real carbon? yes ... the proof test ohmmeter that displays short circuit because carbon is an excellent conductor of electricity.
A zoom on the receiver connection: either you use the supplied connector, or you can use the pads of uart3. In fact the test was ohmmeter proves that it is connected together. So ppm / sec bus on uart3!
Views of the PCB that contains the buzzer and two programmable LEDs located at the rear of the racer.
The vtx is a 5.8ghz 25 / 200mw. Original configured 25mW to stick to European legislation, it is nevertheless unbrid by sliding a small microswitch located inside the machine on the side of the transmitter .. He is seen here, the small dot white to the right of the issuer on the photo.
Under the engines are placed signaling LEDs. Although not programmable as already announced, they are nevertheless visible to locate the ass-ass-head of tê when starting in visual flight.
View esc that are almost next generation in blheli_s.
The screenshots made here are made of origin. Nevertheless, I made an update of these as well as an update to the flight controller before the first takeoff to benefit from the latest developments and bug fixes.
Please note that it will completely reconfigure and recalibrate as your machine after updating !!
Some original betaflight screenshots version .......... (Flight controller program) Application available in Google Chrome before updating.
A dump and a backup file, are available at the end of this article.
On video
Unfortunately I have not had time to make a video .. During his first flight (Maiden) test I forgot to start up the DVR (Recorder) my glasses and following a failed esc it s' crashed after flight 20s, causing the destruction of a carbon unibody arms on the plate and thus revealing the weak point of this one.
However I enjoyed during those really sweet flight 20s and cast (smooth like butter) and really Locke (stalled) on its axis or when cornering. I would not have had a faulty esc it would severely shackled batteries.
It happens…
Conclusion
Although it is a little toy at first, we quickly realize, once taken in hand, the latter is a real racer in itself. Composed of carbon and abs, his look is clearly distinguished from other machines .. With almost last generation components, before we still have time to continue to be riding the wave "hype".
It will nevertheless some knowledge or a talented friend to add, binder and configure its remote control receiver and remote control. (There are only 3 son to connect via servo connector and a little configuration to do but it can put off beginners)
Well balanced and very enjoyable to drive, this device is well designed for smooth flight as for the pure breed!
Not specially adapted for a beginner, unless to hang on and follow tutorials available on the Web, which will be quickly lost in the thousands of betaflight settings (although partially configured original), however, it will delight the intermediate pilots as experienced.
Please note, however, that in a crash this device includes points of weakness on its unibody carbon plate as we have unfortunately noticing.
more photos
Useful links
The drone of the manual
The original configuration dump file
The original configuration backup file
The link to the product on the shop ERC MARKET
This review was wrotten by Shunt belua
