26-Jul-2023, 01:07 PM
My ELRS on GOKU Versatile F405 2S 12A AIO is blinking quickly when radio is on, and not binding . The phrase is default. I have more quads and they all bind without issue to the very same radio
# get expresslrs
###WARNING: NO CUSTOM DEFAULTS FOUND###
expresslrs_uid = 65,245,33,230,58,226
Array length: 6
Default value: 0,0,0,0,0,0
expresslrs_domain = AU433
Allowed values: AU433, AU915, EU433, EU868, IN866, FCC915, ISM2400
expresslrs_rate_index = 0
Allowed range: 0 - 3
expresslrs_switch_mode = HYBRID
Allowed values: HYBRID, WIDE
expresslrs_model_id = 255
Allowed range: 0 - 255
# status
MCU F40X Clock=168MHz (PLLP-HSE), Vref=3.27V, Core temp=51degC
Stack size: 2048, Stack address: 0x1000fff0
Configuration: CONFIGURED, size: 4100, max available: 16384
Devices detected: SPI:1, I2C:1
Gyros detected: gyro 1 locked dma
GYRO=ICM42688P, ACC=ICM42688P, BARO=DPS310
OSD: MSP
System Uptime: 27 seconds, Current Time: 2023-07-26T12:03:34.228+00:00
CPU:14%, cycle time: 123, GYRO rate: 8130, RX rate: 15, System rate: 9
Voltage: 1 * 0.01V (0S battery - NOT PRESENT)
I2C Errors: 0
SD card: Not configured
Arming disable flags: RXLOSS CLI MSP
# Betaflight / STM32F405 (S405) 4.3.1 Jul 13 2022 / 03:32:11 (8d4f005) MSP API: 1.44
###ERROR IN version: NO CONFIG FOUND#### board: manufacturer_id: FLWO, board_name: FLYWOOF405S_AIO
# get expresslrs
Array length: 6
# status
OSD: MSP
I2C Errors: 0
