28-Feb-2024, 10:55 AM
Oh dear, this is maddening....
I've got a Speedybee F405 wing, a Foxeer elrs receiver, and Radiomaster Boxer tx.
The tx and rx are bound. I've got a solid led on the rx. which changes colour according to packet rate. However, there's no stick input on INav, I can't set an arm switch - nothing. I've got tx to rx, and rx to tx on the rx wiring, the soldering is good, the correct uart has been assigned, and crsf has been chosen.
I do get 'rf critically' low message when clicking on the 50hz packet rate. And get get 'telemetry lost/recovered' when unplugging and replugging the rx.
Model match is off.
I haven't however flashed any rx firmware, or set a binding phrase. I DID set a binding phrase for an earlier model with the same tx, but this was with Betaflight. Could this be the problem?
I also successfully bound and flew a mini drone (mobular 7) with the Boxer, without messing around with binding phrases - it just immediately worked with Betaflight.
What more can I do?
Please, feel free to ask as many questions as you like!
Model match is off.
What more can I do?
