Threads: 2
Likes Received: 1 in 1 posts
Likes Given: 4
0 25-Jan-2017, 05:45 PM (This post was last modified: 25-Jan-2017, 05:53 PM by rcgomes.) hello i buy from bangood a wizard 220 drone. yesterday i connect battery and the drone make some noise calibration i guess and then i In the controller it puts the drone to work the motors but never took off ... the fans are put in the correct way !! After several people try to help now the drone does not answer anything !! Neither the engines work and inside the drone there always appears a red light flashing ... did the same thing happen? I should have bought a cheap drone to learn, but not to spend a lot of money I was soon for a better one and now I do not know how it works. What disappointment
Thank you so much for your help and time.
Threads: 30
Likes Given: 714
45 Have you calibrated the accelerometer?
Threads: 2
Likes Given: 4
0 hello, no, frist time i try the drone make some noises and motores move, then i press trotle and fore the drone but never lift even in max RPM up!! dont dont do nothing only conect the batery make the noises and have interior red light fash and never fire up!! maby the radio? in radio options i do a factory reset and no work also. same thing never start drone
Threads: 2
Likes Given: 4
0 thank you very much i will follow this and i will come here to tell if goes right
for conect need a special cable? the drone only comes with battery cable
Threads: 66
Likes Received: 350 in 248 posts
Likes Given: 164
34 you will need a micro usb cable. Same that comes with most android phones
Threads: 11
Likes Received: 21 in 11 posts
Likes Given: 1
3 Did you make sure that the receiver is bound?
Threads: 2
Likes Given: 4
0 hello! sp after a lot of videos etc i finaly conect the drone to the program. this video help me alot
my problem now is when i press litle the throttle in 25% +- and hold, the speed rises automatic. this is normal? in the betafligh in the receiver menu the throtle stay lets say in 1000/1200 but the speed rises in the drone automatic. what is the problem? because in the fly situation the drone will fly away for sure. thank you
Threads: 2
Likes Given: 4
0 i i end up sell the drone!!! i like to buy one Hubsan 501 now maby more easy and no need alot of programing and work right? thank you
