Eachine Wizard x220 frame
Hi
I'm using Eachine Wizard x220 frame.
All other parts are changed.
What frame that's not to expensive should i change to?
Keep it with the parts that are currently installed.
Then you can build another machine on a different frame. This has two advantages: It gives you a second craft to use when you break one of them and it will give you something to compare to the X220 so you can feel the difference between it and the new craft.
Although its quite possible to move hardware around between frames, its not a great idea. Most things don't like to be repeatedly soldered, de-soldered and soldered again. It weakens the connections and causes problems in the end.
  4 inch frame with 16x16 motor mounting holes Pathfinder075 10 242 19-Mar-2024, 07:02 PM
  4" frame that fits GOKU HD 745 EVO 40A AIO Zorik_IL 5 279 24-Jan-2024, 03:00 PM
Last Post: skywanderer
  Eachine V100 vs Fatshark HDO V1 miklere 15 723 13-Jan-2024, 12:59 PM
  Eachine wizard x220 v2 setup shahinsa 4 613 17-Nov-2022, 09:17 AM
Last Post: shahinsa
  Motor issue on brand new Eachine Wizard X220 V2 shahinsa 8 669 16-Nov-2022, 01:01 PM
