Eachine Turbine QX70
Coming soon on Bang Good, a new product from Eachine.
It's a competition for the Tiny whoop.
Here are the specs:
Wheelbase: 70mm
Fly Weight: 54g
Flight controller: SP RACING F3_EVO_Brush
Firmware version: Cleanflight 1.13.0
Motor: 8520 Coreless Motor
Prop Size: 40mm 4-Blade
Camera: 520TVL HD CMOS 1/4 inch Camera
Video Output format: PAL / NTSC
AV Wireless Transmitter: 5.8g 25mw 48ch
Batterry: 3.7V 600mah Lipo battery
Flight time: 6 minutes
Receiver: Frsky / Flysky / DSM2/DSMX
2mm bigger motors and 10mm bigger blades.
I think you can't you use different protocols one on QX70, this because they have all three a different price, so i think the protocol is loaded in the receiver, but i can't confirm it.
A link to the product: http://www.banggood.com/Eachine-Turbine-...95990.html
[Image: 59a571cb-6abf-4fc8-a0d4-4f88bec2edc7.jpg]
I need them ALL! (the tiny qx things i mean)
anyway, all the QXxx have the same board but this one looks really different. Surprisingly, the weight of this one is the same as of the others. Well, most probably, i will add this to my collection if they have it in stock before xmas delayed shipements start to be active.
8mm motors! more power and can carry larger batteries Smile
But wish they had made that antenna a bit lower profile... sticking out like that!
Quote:Description:
The QX70 quadcopter is a improved Indutrix for FPV Racing , flying furiously with adequate agility.It is based on SP racing F3 evo flight controller supports Cleanflight and Betaflight, provide Acro/Rate mode, Angle mode, Air mode and more. More importantly, it is armed with an omnipotent receiver which is compatible with various protocols.
only "adequate," you say... I was hoping more for "violent" agility.
can't tell if that frame is 3d printed or injection molded. hoping for the latter!
gimmie those props!!!!
This is nice!
I will order one once they arrive
  EACHINE E017 BadRaven 9 782 08-Feb-2024, 04:06 PM
Last Post: BadRaven
  Eachine E010 / JJRC H36 Bad Raven 4 414 14-Jul-2023, 03:03 PM
Last Post: Bad Raven
  Help I can't bind Eachine QX 65 with Taranis Q X7 thedroneracingpilot 11 2,134 14-Nov-2021, 12:54 AM
  Help Eachine UZ65 no binding frsky taranis x9 lite rgb_co 16 1,662 18-Aug-2021, 11:58 AM
Last Post: rgb_co
  Shall I desire Eachine Trashcan boredwag 10 1,028 17-May-2021, 07:12 PM
Last Post: boredwag
