Eachine E010 Taranis, easy mod fpv
Presentation
The Eachine E010 is a small quad principally for indoor flight. The small changes made, you will drive with your Taranis in Fpv.
The machine comes with a small radio-type "toy", a USB charger, 4 propellers reserve and a lipo battery 1s 150 mah 30c.
With the use of multi-protocol transmission module, you will be able to control your E010 with a much higher accuracy than that experienced with the original radio. With radio that is provided, the flight is entirely possible but not at all accurate.
The placement of the transmission module is very simple and is done quickly. Simply remove the back cover of your Taranis and clip it to the intended location.
Before your Taranis E010 with your well check the following settings in your radio:
  • external hf on PPM mode
  • channel range: CH1-12
  • Order of ERTA ways
mod Fpv
To take advantage of this beautiful little quad fpv, I added to it a combo cam / vtx I regained my Nano Qx fpv. I also used the original connectivity combo that I soldered on the E010 plate directly on the battery power (on the top). Of course you will find several different combo models that can adapt easily.
I completed the installation of the camera very simply with a small piece of double-sided and Colson. It is also possible to print a 3D part, for having a totally suitable support.
The installation performed is very simple, basic and very light.
The small behaves comfortably in flight and is very accurate. On the side of autonomy, with the mod fpv, I 3min30 with lipo. Which is more than correct.
video review
Conclusion
If you want to make fpv in indoor cheaply, with a small single machine that you can evolve, the E010 is for vous.L 'well known that is the equivalent inductrix fpv will cost almost 3 times the price. Personally I find this really nice machine and I'm going to recommend batteries to extend the good times [Image: 1f609.svg]
You will find here Eachine E010 Banggood and the transmission module here Banggood . If need extra batteries, upgrade and spare parts Here
Enjoy the flights everyone [Image: 1f609.svg]
[-] The following 3 users Like Pimousse's post:
  • Tom BD Bad, Akuwu, Oscar
awesome post..thanks for taking the time bro
Thx for your comment mate
https://pimousse.be/ Belgian FPV & Aeromodelism
  How To Corner FPV Like a Pro - Cornering Drones mattyfleischfpv 0 246 31-Jan-2024, 07:36 PM
Last Post: mattyfleischfpv
  Better FPV throttle control - Improve your stick movement FAST mattyfleischfpv 1 275 31-Jan-2024, 02:15 AM
  <2g GPS Mod - Ultra-lightweight GPS! V-22 18 4,057 28-Feb-2023, 12:00 PM
  An easy way to solder to motor pads with slots Rob3ddd 5 744 08-Jan-2023, 02:54 PM
Last Post: iFly4rotors
  Tutorial FlySky i6X mod more than 4 switches psicho100pro 2 1,452 02-Jan-2023, 09:34 AM
Last Post: notsopilot
