31-Aug-2016, 02:48 PM (This post was last modified: 31-Aug-2016, 02:54 PM by Carlos Costa.)
If you like many others, like flying over bbq pits with your tiny whoop and had this happen to you:
Don't fret! You can now replace your frame if it's either damaged or just because you want a different one - cheaply!
Banggood is selling a new micro quad called Eachine E010 that has components that are compatible with your Tiny Whoop!
The Tiny Whoop components fit well in the Eachine frame with only a slight mod to fit the battery.
You can buy the whole thing and get some spare components or simply get a replacement frame
Replacement time: 15 mins
Firstly, remove the cover from the eachine and unscrew the two screws that hold the board in place.
Unfortunately you will also need to cut the motor cables to get the motors off but you can always reuse them for another build
After removing the screws and the motors you are left with the frame. Do the exact same thing on your inductrix (4 screws instead of 2 and you can unplug the motors rather then cutting them off.
Now you are ready to put your inductrix electronics in your eachine frame. 3 of the 4 motor holds line up perfectly and will hold your FC in place.
I found the hardest part was to put the motor connections back in place ... took me twice the time I spent in dissembling everything!
You are almost there.
Once you get your motors and props in placed in the correct way you should have something like that looks more like an inductrix and less like something that had a bad trip in FPV fire terror town.
The last part is to cut a little snipped of the end of the battery holder so the inductrix battery can fit all the way in.
That's it! Go fly
Here is the modded inductrix side by side with the eachine.
Which one is which? (that's a rhetorical question you don't actually have to post an answer).
That's it! Go fly
