06-Mar-2017, 09:03 AM (This post was last modified: 06-Mar-2017, 09:54 AM by streetcsaba.)
I just got this camera from Banggood to review.
It has very high quality and excellent soldering job.
It is very energy-efficient, if used on 25 mw it doesn't even get warm.
it is easy to mount anywhere, a rubber band is enough. The antenna connection seems solid.
The menu is easy to navigate, with more than enough options.
The DVR system is excellent, it automatically starts recording as soon as it gets power.
Pros:
-Simple menu
-DVR
-Good soldering job
-Big power output
-Relatively wide voltage range
-Supports both NTSC and PAL
-Lots os supported frequencies
Cons:
-Size (because of the DVR so it's okay)
Verdict:
Excellent camera. Adds an unusual but useful feature to similar AIO combos, the least painful way possible.
Videó:
If you are interested in buying it, you can do so here: https://goo.gl/GlHDwG
Pros:
-Simple menu
-DVR
-Good soldering job
-Big power output
Cons:
Verdict:
Videó:
