Eachine Beecore Help, Keeps beeping
Hi,
I have just received the Beecore with Frsky receiver.
It works great, default firmware and settings, but there's a continuous beep as long as the motors are spinning.
I have disabled the Vbat as i thought that was it, but no luck so far..
Can anyone help please?
Thanks!
*****EDIT*****
It turns out it was the motors pwm rate.
Changed it from 1000 to 16000 and the noise is gone.
You installed a buzzer on the Beecore? Where did you connect the buzzer to?
(02-Dec-2016, 03:18 PM)Oscar Wrote: You installed a buzzer on the Beecore? Where did you connect the buzzer to?
I did not Confused something there beeps..
https://www.facebook.com/shay.ganor/vide...046179916/
I can't view your link, probably permission issue.
Very odd. Can you try disconnecting one motor at a time to see if still always happens? (It's a loud beep for the board - and I don't know what would beep in a motor, but I'm wondering if it's just a weird resonance thing with one of the motors.)
Edit: If it goes away with one of the motors disconnected, then plug one of the other motors into that port and see if it returns. If not, it's motor-related. (If it does return, it's the board.) If the beeps never go away, I'm stumped. I've got one of these boards to put on an E010, but I haven't got to that project yet. I might move it up in my list....
Good luck!
  • ShaygA
Thanks man.
Cool
[-] The following 1 user Likes ShaygA's post:
  • sloscotty
but there´s no buzzer port right? at least no pads stating Buzz or something like that
I don't think so..
Mine was doing the same thing but I thought an electric component was doing that sound. But anyway, thanks for sharing, I fixed mine too
  EACHINE E017 BadRaven 9 784 08-Feb-2024, 04:06 PM
Last Post: BadRaven
  Eachine E010 / JJRC H36 Bad Raven 4 420 14-Jul-2023, 03:03 PM
Last Post: Bad Raven
  Help I can't bind Eachine QX 65 with Taranis Q X7 thedroneracingpilot 11 2,136 14-Nov-2021, 12:54 AM
  Help BeeCore V2 radio failure WheezyProp 9 1,973 08-Sep-2021, 04:02 PM
  Help Eachine UZ65 no binding frsky taranis x9 lite rgb_co 16 1,662 18-Aug-2021, 11:58 AM
Last Post: rgb_co
