Threads: 6
Likes Received: 0 in 0 posts
0 Hi All,
How do you calibrate DYS XS30A ESCs?
I have connected to Betaflight, set motor tab to max and plugged in the LiPo.
The ESC plays no startup or programming tunes .....
My min throttle is set to 1000 and max to 2000.
Is there another way to calibrate these ESCs?
TIA.
Threads: 66
Likes Received: 350 in 248 posts
Likes Given: 164
34 28-Aug-2016, 04:36 PM (This post was last modified: 28-Aug-2016, 04:36 PM by oyvinla.) They escs (actually the motors) should make a sound as soon as you power them up, no matter if it is connected to the fc or not. Have you checked that they actually get power?
Threads: 66
Likes Given: 164
34 I see. You could try to calibrate them in the blheli gui
Threads: 96
Likes Received: 531 in 218 posts
Likes Given: 188
20 what FC are you using? some of the old Naze32 Rev.6 has a diode issue that will prevent you from calibrating ESCs
Threads: 96
Likes Given: 188
20 I would try to do what oyvinla said and try to use BLHeli suite to calibrate.
Threads: 0
0 Hi,
I have same problem related to ESC DYS-XS30A ESC.
I'm using Racing F3 EVO but I can not calibrate ESC. I have tryed with Cleanflight and Blheli suite and they can not sync. Once I put throtle at max and connect power to the ESC there is no sound.
Has someone found this problem?
