28-Mar-2016, 09:13 PM
DYS is releasing the new MR series of mini quad motors, designed for multirotor racing.
Looks good quality magnets, bearings with hand-wound single strand coils.
These motors include a lock nut to secure your propeller which makes it much easier to swap your propellers when they get damaged. Also it makes building your FPV racing quadcopter much easier as you dont need to figure out which motors has a CCW thread and or CW thread.
Wonder how they compare to the EMAX RS2205 motors.
MR2205 2300KV
Configuration: NP Stator Diameter: 22.0mm
Stator Length: 5.0mm
Shaft Diameter: 3.0mm
Motor Dimensions(Dia.*Len): Φ27.7×18.5mm
Weight (g): 29.5g
No.of Cells(Lipo): 3-4S
Max Continuous current(A): 24.1A
Max Continuous Power(W): 356.7W
Internal resistance: 0.012Ω
MR2205 2750KV
Pull: 1150g
Motor size:Φ27.7×18.5
Battery: 3-4S Lipo
Specifications:
KV: 2750
Configu ration: NP
Weight (g) : 27.5g
No.of Cells(Lipo) : 3-4S
Max Continuous current(A) : 35.8A
Max Continuous Power(W): 529.8W
Internal resistance : 0.06Ω
MR2205 2300KV
Weight (g): 29.5g
MR2205 2750KV
Pull: 1150g
Battery: 3-4S Lipo
Specifications:
KV: 2750
Configu ration: NP
Weight (g) : 27.5g
