Durable prop recommendation for a Nighthawk 280
Hoping for a prop recommendation.
I'm flying a 280 Nighthawk and am currently using HQ 6450 bullnose props (2 blade).
3s battery.
I'm new to quads so I don't care about top end speed yet.
I'm hoping to find a more durable prop (less brittle). Also, if there are slow speed handling advantages to using a 3 bladed prop, I would like to switch to that for awhile.
Any prop recommendations that won't stress the ESC's?
Is there typically a flight time difference between 2 blade and 3 blade?
Thank you.
Yes, more blades pull more thrust but also draws more current. But generally speaking more blades almost always gets more inefficient. This article might explain this matter in a bit more detail https://oscarliang.com/quadcopter-motor-propeller/
The kingkong 6045 is very durable
You could also try 5 inch if you don't want as much thrust for now. Kingkong tri blades are nice and cheap
Thank you for the info and article link.
  Solved Prop noise when releasing throttle skamtastik 6 322 28-Jul-2023, 12:43 AM
Last Post: skamtastik
  Prop Colours Bad Raven 11 386 02-Jul-2023, 04:04 AM
  Discussion When is a prop too damaged? Lemonyleprosy 21 2,073 01-Jul-2023, 07:39 PM
  Motor recommendation - more power opossum.fpv 1 316 28-Apr-2022, 04:20 AM
  Longer prop vs higher pitch opossum.fpv 2 355 28-Apr-2022, 03:57 AM
