DShot beacon functions but actual buzzer doesnt
Hello,
I have double checked that my buzzer unit is connected. But I am unable to get it to make noise through the quad.
It is not too big of a deal because the Dshot beacons work but it would be nice to have a louder buzzer.
Does anyone know if there is any particular settings in beta flight I need to enable/disable?
I did attempt all of the console commands provided by the manual.
Thank you.
What buzzer do you have? Provide link.
What is your beeper tone setting in CLI?
(20-Jun-2018, 08:34 AM)voodoo614 Wrote: What buzzer do you have? Provide link.
Hello,
Thank you for your time in responding.
I have a Mantis 85's default buzzer. It is a small piezo buzzer. Standard +/- legs.
https://www.banggood.com/Happymodel-Mant...rehouse=CN
This quad is running this FC
https://www.banggood.com/Super_S-F4-2S-F...rehouse=CN
I do have the wires connected correctly as indicated by the + sign above the ulterior leg.
The beeper tone settings in BetaFlight are as follows:
# diff
# Betaflight / OMNIBUSF4 (OBF4) 3.3.3 May 31 2018 / 13:23:55 (3565182d3) MSP API: 1.38
# name
name PuntangBoomerang
# resources
# mixer
# servo
# servo mix
feature RX_SERIAL
feature MOTOR_STOP
# beeper
beeper -RX_LOST_LANDING
beeper -ARMING_GPS_FIX
beeper -READY_BEEP
# map
# color
# mode_color
aux 0 0 1 1975 2025 0
aux 1 1 2 975 1025 0
aux 2 13 0 1975 2025 0
aux 3 28 2 1475 1525 0
aux 4 35 3 1975 2025 0
# adjrange
# rxrange
# vtx
# rxfail
# master
set mag_hardware = NONE
set baro_hardware = NONE
set fpv_mix_degrees = 25
set serialrx_provider = IBUS
set blackbox_p_ratio = 31
set blackbox_device = SERIAL
set align_board_yaw = 90
set vbat_max_cell_voltage = 42
set vbat_min_cell_voltage = 37
set vbat_warning_cell_voltage = 36
set beeper_frequency = 10000
set beeper_dshot_beacon_tone = 5
set osd_warnings = 57
set osd_vbat_pos = 396
set osd_tim_2_pos = 2454
set osd_flymode_pos = 2081
set osd_power_pos = 2433
set osd_warnings_pos = 2378
set osd_avg_cell_voltage_pos = 2444
set osd_disarmed_pos = 2251
set osd_stat_min_rssi = OFF
set osd_stat_max_curr = OFF
set osd_stat_bb_no = OFF
set vtx_band = 2
set vtx_freq = 5733
set vcd_video_system = 2
# profile
set p_pitch = 61
set p_roll = 42
set p_yaw = 89
# rateprofile
I had a failsafe today in a field. The Dshot buzzer saved me but it sounded an awful lot like the bird chirps in the area at the time! Was quite scary in the tall grass.
Set beep frequency to zero.
(21-Jun-2018, 02:13 AM)voodoo614 Wrote: Set beep frequency to zero.
Voodoo,
When I had set beeper_frequency = 0 the little buzzer does not activate still.
I will swap the wires to make sure the silk screen isnt incorrect.
It really looks like you have everything correct. You can just put 5V to buzzer to make sure it is working.
(21-Jun-2018, 07:56 AM)voodoo614 Wrote: It really looks like you have everything correct. You can just put 5V to buzzer to make sure it is working.
Hello,
The 5 volts did work.
I believe it is a software issue with this Super_S F4 board.
I appreciate your time in responding.
  where to buy tiny Lipo for buzzer/finder niuk 1 255 14-Jul-2022, 05:39 PM
  Review VIFLY Wireless Beacon/Buzzer bffigjam 4 2,056 22-Sep-2019, 12:01 PM
Last Post: Oscar
  Flight controllers with 8 DShot outputs cche 1 772 22-Sep-2018, 07:39 PM
Last Post: sushicanfly
  Switch buzzer to led? Redazu 5 3,871 16-Oct-2017, 03:32 PM
Last Post: McDee
  Actual size layout diagram of screws Airvelations 3 989 14-Jun-2017, 05:38 PM
Last Post: sloscotty
