DON'T CLICK HERE!
What? Why would you click if it says you shouldn’t? You like to push non meaningfull rules don’t you huh? Well this might allow me to get more views for the giveway...
Well since you’re here now, this is my first build log.
After finding out the my fc has a shorted 3,3v circuit I orderd the mamba f405 stack.
Here it is in all its beauty.
[Image: Gfq3F9Nl.jpg]
This is the old stuff
[Image: ORK8s3tl.jpg]
I’ve decided that I would just take the whole thing off and replace it with the stack while I get myself a spare fc for the working esc. So, time to desolder.
Once desolderd
[Image: 7Waa1ual.jpg]
New esc solderd on. I had a lot of trouble fitting that thing and wiring it. In fact i had to put it sideways and upside down so that it would fit.
[Image: mWtD1rGl.jpg]
Next the fc
[Image: ogpUvWal.jpg]
And configuring.
The finishing touches would be: heatshrink, props and battery
But sadly this is where it ends and the troubleshooting starts, as when I spin the motors up in betaflight on the pc, they work fine but once on the fc, problems occure.
As soon as i have fixed that, i will post the maiden flight.
Thanks for reading and let me know what you think Smile
Final pic:
[Image: wUR0mM4l.jpg]
Signed by me :-)
[-] The following 2 users Like Smoses221's post:
  • Smokie, hugnosed_bat
May I suggest to change your motors so that the red wires go on the front or back of the quad, I personaly think it would give a good finishing touch Smile
(28-Oct-2019, 03:08 PM)brnmd Wrote: May I suggest to change your motors so that the red wires go on the front or back of the quad, I personaly think it would give a good finishing touch Smile
Yes, you may suggest that, but actually it is already the case. The fc is turned 90 degrees because thats the only way the esc would fit. :-)
This is why the XT60 comes out of the left side.
Signed by me :-)
marketing guy! cheater! ;-)
i tought i do something crazy by the click x-D good luck for the giveaway ;-)
how does the racerstars work? impressions about?
  • Smoses221
(28-Oct-2019, 03:14 PM)Smoses221 Wrote: Yes, you may suggest that, but actually it is already the case. The fc is turned 90 degrees because thats the only way the esc would fit. :-)
Then don't use props in, that usb port could get full of dirt, etc...
(28-Oct-2019, 06:28 PM)hugnosed_bat Wrote: marketing guy! cheater! ;-)
Haha thanks gl to you too! The racestar worked great but i didn't have enough time with it too really test the durability.
(28-Oct-2019, 06:39 PM)brnmd Wrote: Then don't use props in, that usb port could get full of dirt, etc...
Thanks! I didn't think of that Big Grin
Signed by me :-)
I don't have a way to record dvr and don't have a gopro attachement so this silly edit while have to do
Smile
Signed by me :-)
(28-Oct-2019, 06:58 PM)Smoses221 Wrote: Haha thanks gl to you too! The racestar worked great but i didn't have enough time with it too really test the durability.
May I suggest you just get some of these dust plugs https://www.banggood.com/Eachine-Wizard-...379201608N
I'm really IntoFPV
Youtube|Instagram|Facebook|Steam
Don't forget to rate people who have helped you!
(01-Nov-2019, 08:38 AM)bffigjam Wrote: May I suggest you just get some of these dust plugs https://www.banggood.com/Eachine-Wizard-...379201608N
Yeah well actually the connector is covered by the connector of the vtx antenna but ill buy some anyway.
Signed by me :-)
  Help Quad Shut down in mid air, Don't know whats wrong w3njember 21 2,289 04-Sep-2019, 07:59 PM
Last Post: bLoWsMokE
  Build Flyno Aether 6" 6S Build - Do's & Don'ts RENOV8R 9 1,012 12-Oct-2018, 04:17 PM
Last Post: RENOV8R
  Don't mess with GoPro settings the night before big days :D Oscar 4 983 19-Apr-2018, 11:07 AM
Last Post: Drone0fPrey
  Bench Test: Motors don't slow down when reducing throttle Carl.Vegas 10 5,142 17-Oct-2017, 05:31 PM
Last Post: unseen
  Tip & Trick Mini Quad parts list - Don't miss a part! Oscar 0 25,521 30-Aug-2016, 01:22 PM
Last Post: Oscar
