27-Apr-2016, 01:03 AM
So, I posted about my nasty crash resulting in an arm getting snapped off my 4mm frame. I have replaced the frame and installed a new motor and ESC because I never found the arm. So, everything swapped over and I went to calibrate the new ESC. However it won't calibrate. When I try calibrating the new ESC individually, it will make no calibration tones when I plug in the battery. And when I drop the slider to min throttle, I just get one beep. Also, blheli doesn't recognize it.
Thought it was just a bad ESC, so I installed a new one. Same thing happens. Did a custom motor mix and swapped the ESC to motor 5 in Cleanflight. Does the same thing. Odd thing is the other 3 motors calibrate fine and are read in blheli. I haven't tried to fly it but everything else seems normal, only the new ESC is out of sync with the other 3...it starts later and seems to max out sooner.
Sound like a bad FC? I reflashed betaflight but it didn't help. Thing that has me stumped is the other 3 motors act fine and I can connect to them in Blheli. But, when the arm was ripped off it tore all the wires and its possible they shorted, but the battery was disconnected when I found it.
I have a new naze 6 here I could use, but with all the talk about its gyro I think I'll just get a cyclone or something. But hopefully there are some clues here you guys can pick up on. Thanks!
