dji motor test
The daylight video is with Phantom 2212 920kv. The night video I switched to the 2312 960kv. Both was running the same 5200mah 3s lipo. Let me know what you think.
you have a lot of vibration on your quad, you could check which motor/prop is generating it and investigate, then your movies will have much lower jello effect.
if lazy:
check prop balance
if not lazy:
investigate motors + props => much lower vibration
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
(26-Oct-2016, 11:21 PM)Grisha0 Wrote: you have a lot of vibration on your quad, you could check which motor/prop is generating it and investigate, then your movies will have much lower jello effect.
if lazy:
check prop balance
if not lazy:
The new dji motors are so much better. I know it is hard to tell in the night video. And I have my gopro hard mount, and that doesn't help the jello. The phantom motors came off my fc40 that had well over 150 flights, I would say the bearings are getting to the end of there service life. My next motors for my f450 will be something bigger then 22's, maybe 3508 or 3108? I would like to get a little better flight times.
  Chimera 7 motor replacement video Duke Nukem 0 463 19-Sep-2023, 04:28 AM
Last Post: Duke Nukem
  Conformal Coating Ultimate Test! relentlesstech 11 880 01-Apr-2023, 07:54 AM
Last Post: Luz
  Happy model EP1 true diversity rx test. martijnv 0 557 11-Feb-2023, 04:08 PM
Last Post: martijnv
  New Build Test Run relentlesstech 0 228 13-Jun-2022, 05:24 PM
Last Post: relentlesstech
  Hero 7 Naked Test zerogravity 0 244 09-May-2022, 05:58 PM
Last Post: zerogravity
