(02-Dec-2019, 04:29 PM)Oscar Wrote: Thanks John I just edited and added some highlighted features in your post. It's great that DJI is listening to the community
No problem Oscar, you made the post much better....
So, how to get OSD items to work? It is pretty simple actually. Go into the goggle menu:
Settings > Display > Custom OSD > Set to 'On' Now connect your FC to the Betaflight app and select the OSD items you want to display and just drag them around the screen as you normally would on a analog setup. See the screenshot below for an example of how I have mine set up (just 'craft name', 'mAh', 'RSSI' and 'Voltage'. You need to bunch the items together a bit if you want them to show properly in the actual OSD. Also, they'll be partially translucent if placed anywhere but in the bottom line. If you place your OSD items in the bottom line they'll be white and better to read. Power hacks, i.e. 700mW and 1000/1200mW still work with this new firmware, provided you power cycle the goggles and the Air Unit(s) after updating.
And the ability to connect the radio directly to the computer with a USB cable and use it in flight simulators is great! ( Should have been there from day 1, but better late than never )
Like listening to 80s and 90s music? Perhaps you will like my FPV Channel. Concerned about regulations? Join the FPV Freedom Coalition.
