Threads: 9
Likes Received: 1 in 1 posts
0 22-Apr-2023, 08:24 PM (This post was last modified: 22-Apr-2023, 09:07 PM by lew046.) Hi! Iam new to hd fpv.
I got a DJI FPV Googles v2 (not the new googles 2)
Iam rooted and installed fpv wtfos and FCC hack
however how can i switch the googles to FCC (US) mode to allow acces to all 8 channels?
Threads: 589
Likes Received: 8,997 in 6,660 posts
Likes Given: 1,426
790 If you have WTFOS installed then just install the "fcc‐unlock" package too (on both the Air Unit and Goggles), then the FCC hack will be (re)applied for you automatically at each bootup without you needing to do anything else.
Threads: 589
Likes Given: 1,426
790 22-Apr-2023, 08:47 PM (This post was last modified: 22-Apr-2023, 09:03 PM by SnowLeopardFPV. Edit Reason: Corrected some information. ) You only get all 8 channels if you use the 25Mbps mode. The 50Mbps mode only gives you 4 channels (1, 2 & 3 plus public channel 8).
With 50Mbps mode there is no room for 8 channels on the 5.8Ghz frequency band because each of the channels (with the exception of public channel 8) uses double the normal bandwidth so there can only be 4 channels.
Threads: 589
Likes Given: 1,426
790 The bitrate is set on the Air Unit so yes you need the goggles bound with an Air Unit before you can change that and some other settings.
